SOURCE: Does Best Buy install car alarms by viper
Best buy will install viper car alarms, but I would strongly advise against getting any work performed by their techs. I had one installed on my truck and aside from not working properly, the cruise control, heater control unit, power windows, sunroof, and gauge cluster have stopped working. All that on top of intermittent stalling on the interstate. So far the repair estimate from a Toyota dealer is nearing $2000.
While this may be an isolated incident, Best buy will certainly not get any more of my money.
SOURCE: Viper Alarm System problem
Look for a push button under the dash, should be black, turn key on and hit button.. should go into "valet mode".. hopefully you will be all set...
SOURCE: Viper alarm, lights dont flash
Sounds to me like the parking light output wire. They usually have a seperate fuse or the connection is bad. The connection on your vehicle should be behind the pass side kick panel and look for a wire to the white/purple wire and check that with a meter or light to see if it's kick out power. There is a possibility they used the negative trigger through a resister and that would be located behind the headlight switch. That will at least let you know and trace down the problem. Here is a link with that parking light info for yours. Hope this helps and let me know if you have more questions.
http://64.85.6.121/diagrams/printpage.asp?ModelID=17258&MakeID=16
SOURCE: Replaced the battery in my car need to reset my viper alarm
Alarms are not supposed to shut down the engine while you are driving if it was installed properly. Could be another installed accessory or the car itself has a problem. If it was in anti-hijack mode, you would receive a warning like honking horn. You may have to visit a repair shop and maybe your local Viper dealer to have them take a look. DC
SOURCE: viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
