SOURCE: No voice sound through speaker with DVD system, only music?
first check the settings on the audio menu of the dvd player. make sur it is set to 5.1 (if available) otherwise set it to stereo and your system should decode it.
assuming the second step is okay : as other dvd you play seem to work) it still may be that your unit is decoding stereo inputs just fine and 5.1 is not working properly....
so if adjusting audio settings in dvd play back menu dont work,
check that the cables to the satellite speakers are connected correctly and all plugged in soundly ( voice is high frequency,- coming from satellites - the garbled noises you hear are the base ( low freq) elements of voice which are coming from the bass box ( that the X.1 part of 5.1) and so that is obviously working. ,
SOURCE: Sylvania SMPK8854B MP3 Player File Format Error
hey, the way to do it is to install that little cd that came with it and save them to your desktop…now when you see them appear open the AVI converter…this will bring up a screen that asks to add the videos you want to convert and also a destination…just browse that and find your video that you want to convert and then make the destination the mp3 player and click convert…and whallaa! it will be ready to look at in your mp3 player…takes some playing with, but you’ll get it…God bless! <><
SOURCE: when watching a DVD, the surround sound plays all
If there is nothing at all from the center channel while watching a DVD, first try resetting the system (unplug the power cord from the sub, and the DC power cord from the media center for 30+ seconds) If a reset doesn't help this, run the "adaptIQ" setup disc again. Honestly, this is a very odd problem for that system to have. (especially since we know the center speaker works for other sources) I hope this helps.
SOURCE: how to install the mounting bracket to JBL control 25?
big red
they allways have a screw in the back you just tighet it and level your speaker
