If your speaker supports Bluetooth. Use the screenshots below to connect to your device. If not, you can use a wire from your iPhone to the speaker. it looks like the last screenshot below.
On your phone...
Go to Settings and then Bluetooth. Turn on Bluetooth. Look for your JBL device under "OTHER DEVICES" and tap on it to connect.
On your speaker.
Turn on pairing mode for your JBL deivce
Find your JBL device on your phone or laptop and pair them
Confirm successful pairing
JBL speakers typically have a dedicated Bluetooth button to use to pair your speaker.
Bluetooth
SOURCE: HI ,
Impedance must be matched to have a better sound performance. Althought, it has no problem b/w 4 Ohm and 6 Ohm impedance-it still work but the system may get hotter due to impedance mismatching. You can try and see how the sound goes.
Testimonial: "Thats good advice."
SOURCE: Hi I have just got
I guess you didn't get the owner's manual, huh?
http://www.jbl.com/HI-IN/Products/Pages/ProductDetails.aspx?PID=SCS200.5BK/230
Where are the amplifiers in this scenario?
Page 8: The sub needs a subwoofer Line Level pre-out from an AV Receiver or multichannel processor. Though not elaborated on in the manual, the L and R Line Level RCA connections are probably for use if you lack a Sub Out feed. Running L and R from your receiver would allow the sub to derive a Sub Channel.
The rest of the speakers would connect to the AVR's speaker outputs.
Pasge 9: Alternate method if your eelctronics lacks a volume-controlled sub pre-out. This method routes only the front speaker level power to the sub so it can extract something resembling an LFE channel, then it routes speaker wire out to the front speakers, not as an audio power source but simply as a pathway.
You still need amplifier channels for all but the sub.
SOURCE: Is it totaly ok to just connect one pair of JBL
The only relevant speaker spec is the impedance. As you probably realize the Pioneer SX-255R recommends 8 - 16 ohm speakers.
Four ohms is on the hairy edge of too low. You could certainly try it but if any strain or excessive volume is used you could see something go poof!
The low end of 120Hz says don't push the bass to them.
Is it showing anything like " headset" maybe? Sometimes that's what the speaker is recognized as
