SOURCE: forwarding a call
Lift handset, dial 3 or 6 ( depending on model) - key outside line access code - key phone number (eg mobile)- key # - hang up
SOURCE: Call Forwarding
There is a feature that allows this to be done, however it is a security risk. Calls can be hacked and routed to anywhere in the world charging long distance to you. If you need it dont then it will need to be done by an installer. Passwords (will be needed) and the programming tool (will be very helpful).
SOURCE: My kids set Dial Lock
hi you can use this way :
1 {MENU} --> {#} -> {2} -> {5} -> {1}
2 Press {*} -> {7} -> {0} -> {0} -> {0}
3 {Save} -> {Yes} -> {OFF}
SOURCE: Panasonic KX-TG1100 Cordless phone manual
https://www.manualslib.com/manual/648850/Panasonic-Kx-Tg1100e.html
