Staples SPL-P500 Printing Calculator Logo
My SPL-P500 calculator will not print. It says error in left corner and I can use it if I don't print. what do I do?
2helpful
2answers
Why doesn't the equal button work when I do additions and subtractions?
Your calculator is fine. It is an adding machine first, so it uses adding machine logic and you hit the star button to print the total on the tape. The equals sign is only used when multiplying and dividing.
Adding machine logic is as follows:
5+ total 5
3- total 2
7+ total 9
* print out total
Good luck,
Paul
How do I load the paper in my SPL-P500 calculator?
Try making a point and feed it in the right place, the feed roller which is only about 1/2 inch wide should pick up the paper.
How to change ink rollers in calculator
How do you change ink in the Staples SPL-P500?
6helpful
Setting date on Staples SPL-P500 calculator
You press TIME and then you have a button = (it's also written SET on it) press for few second, it will flash, you can now set the date, DD-MM-YYYY than =/SET than TIME again then, =/SET you can now set the time ( the button X / AM-PM to set am or pm) you press =/SET when you're done, and you're set !
3helpful
How to feed the paper into the SPL-500 and how to set for printing?
You feed it from the back,(you will see an horizontal line) you're paper has to be straight cut, than you press the arrow on the left corner until you see it on the front.
Where can I get instruction on a spl-p500 calculator
Go to a web search page and type in spl-p500 calculator instruction manual.
Top Staples Office Equipment & Supplies Experts
Mitch Vass
Mitch Vass
NOEL
NOEL
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
