Question about Canon PowerShot G16
Canon G16 How to replace the back up battery?
How do I bypass or remove the delay upon starting my Yamaha G16 A/E cart?
Not supposed to have a delay. Something is wrong.
Possible causes are Starter/ Gen bad, loose belt or worn, I am thinking this a gas cart? Usually G16 A is gas and G16 E is electric.
Apr 05, 2017 | Golf
Locating solenoid switch on 1999 esteem. Drained radiator last night to fill with antifreeze, then car would not start! Had no problems before. wondering if maybe we pulled a wire loose some where?
depending on how the radiator was drained , ( bottom hose off or tank tap) it is possible that the wire to the crank position sensor was disturbed
run the fault codes to check for other possible wiring problems or sensor failure
Nov 29, 2016 | 1999 Suzuki Esteem
On a 2000 Suzuki esteem 4 cylinder 1.8 I am having to replace the timing belt idler pulley. I need to know what the mounting bolt looks like and its measurements.
cam is change drive on all j18 engies
you lost parts?
cant guess your job,or history.
say the job first , then ask a question.
cam chain loose and making huge noise?
or is the the fan belt.
the G16 does have belt and we have posted 3 books covering it here.
cam belt, g16= 1.6L,or 1600cc engine. different to max this.
Jan 07, 2016 | Suzuki Cars & Trucks
Starter location on a 1999 suzuki vitara
posted 100 times
answered the same,
on the right. on G16, J18/ J20 , H20,h25 h27 engines.
and 1000s answered here, ++++
remove battery neg lug. (or boom eat acid)
remove all wires on starter solenoid.
unbolt the 2 bolts holding it in (at its base)
it falls out.
if you post what engine is there (they come with 3 sizes)
we can show short cuts. ill post the G16 short cut now.
The FSM book will not cover this , it just says, remove starter
because all mech , know how to remove starters. is not covered in the factor service manual. (gee look at it, is it not obvious what it needs? )
http://www.fixkick.com/belts.html#starter
here is the G16 tricks of trade.
the G16B MPI engine (not the A) has manifold brace under the intake manifold, that is in the way, but what engine you have.
Ive not a clue. so cant wax smarter.....
Apr 28, 2015 | 1999 Suzuki Vitara
Canon G16 is asking me to set the date/time every time I change its battery
There is a small battery INSIDE of the camera. It may need to be replaced OR the camera may have a short inside causing it to drain. If you need to have it serviced or if you need the correct battery, try this site: www.CamerasAndParts.com They just deal with the Canon's and they know these Canons well. They can either service it for you OR they should be able to sell you the part. It's the only place we recommend for the Canons. They are excellent and about half the cost on services as most other places.
Nov 29, 2014 | Cameras
Starter
The G16 engine, its under the intake manifold down near the flywheel
bell housing. there is a brace there that makes it harder to get out.
are you sure is bad, do these tests yet.
http://www.fixkick.com/nocrank.html#tricks
nut shell G16:
remove neg log from battery,
then read the FSM page here
chapter 6D covers this.
http://www.acksfaq.com/96-FSM-v1-6D-pdf.htm
see page 6D2-5 "replacement"
but forgets.
2: remove EVAP canister from body, ( couple bolt)
3: gaining access tot he under intake manifold brace
remove this brace makes, starter work 10x more easy.
here is the G16 starter, exposed, lower left, black shinny paint?
http://www.fixkick.com/engine/97-motor-pull/HTML/image_50.html
less intake man.
fresh motor install.
PS.the starter is bad if hot wiring the solenoid fails. (charged BAT)
Feb 10, 2014 | 1994 Suzuki Sidekick
Canon powershot
It really depends on the model of Powershot camera you purchased if it can shoot Raw format or not. I jbelieve the only model available currently that can is the Powershot S120 & G16, the older ones cannot. You can check your models capability at DPReview.com for more information on your camera model.
Dec 22, 2013 | Cameras
My Suzuki esteem wont get fire to the plugs, we've replaced the coils and fuel pump and got a new batterie. still wont crank up
wow no year stated or engine option,,,,, a hard row to hoe.......
the pump dont create spark but all cars cut fuel if there is no spark.
for , fire safety. fix spark first. ignore all other symptoms.
Cranks but does not spark is the #1 symptom.
2nd is no spark, i guess that means at all spark plugs and not one?
what engine do you have,, Esteems dont come one just 1 engine.
so discover that engine, code, like G16 or J18?
The G16 has distributor, the J18 has COP coils x4
apples and oranges different.
So i will answer non specifically.
When you crank, does the tachometer needle move about 300 rpm?
with the scan tool do you see DTC errors as you crank for 5 seconds> release key and look? with key still on>?
P0340s 355s? etc>?
when cranking does the scan tool show RPM? moving up scale?
if car is 96 or newer year, the car has 2 devices that makes spark
one is CMP and the other is CKP. on the G16 engines, it
only needs CMP to make spark ( then ignitor, then coil, the distributor.) did you change you G16 timing belt at 60k miles>?
if not it may not generate spark due to the dizzy timing is way off now.
the J18 engine has no Dizzy (distributor) it has COP.
aka: DIS Distributorless ignition System
The car has CMP on the back side of the left cam.
It can go dead, but the ECU will tell you this fact of you use
as scan tool in the proper way,
the proper way is to crank for 5 seconds, and release key
and look for stored codes. do not turn key off,
until you scan for DTCs live, in memory or pending.
The J18 has 4 COPs check each for spark, not just one.
you can swap the bad ones around , and see if its bad.
post engine size and year, and you'd be amazed at better posts.
Sep 14, 2013 | Suzuki Esteem Cars & Trucks
What is the spark plug gap for a 1993 G8 &2001 G16 Yamaha golf cart
On the 1993 G8 it's 0.7~0.8mm
On the 2001 G16 it's 0.7~0.8mm
0.028~0.031 inches is the same measurement if you prefer in over mm
Here's the G8 manual: http://www.yamahagolfcar.com/partsandservice/assets/pdf/om_0000000061_QJZ6T.pdf
Here's the G16 manual: http://www.yamahagolfcar.com/partsandservice/assets/pdf/om_0000000095_LIKYT.pdf
Hope that helps!
Aug 26, 2011 | Computers & Internet
Canon PowerShot G16 Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
