SOURCE: Kenmore / GE side by side defrost drain keeps freezing up
Check under the base, the tube must be clear to the water tray, often there is a rubber flow restrictor, this either perishes or blockes, either way remove it, defrost over night and then turn back on, should then work ok within 24hrs. Regards Adbvisor
SOURCE: Candy Futura Fridge Freezer
very simple fault - drain hole is blocked. push something flexible down the hole till it clears and water flows away freely
SOURCE: Defrost Drain clogged
Take a spray bottle with VERY hot water and spray it down the drain line
Testimonial: "Good advice. Wife called repairman before I could apply. Repairman did same thing, but with pressureized."
SOURCE: Refrigerator freezer drains keeps freezing over, not plugged.
Your drain tube may
be stopped up with ice at the upper end because it drains too slow because it's
stopped up at the lower end in the evaporator pan under the unit at the floor.
It can get dust and mold in it. Once you get the ice out at the top a little
pressure with a turkey baster will
usually clear it out. Flushing it out with hot water and clorox may help. Make
sure it drains quick enough to prevent refreezing. . The drain should be
located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the
heater and put the other end a few inches down the drain. The heat convection
may prevent it from freezing.
SOURCE: Freezer forming Ice on the bottom not draining water
pour some hot water in the drain if this does not work use compressed air
Testimonial: "So far that worked great, we will see if it continues to drain when the freezer is back on and does it defrost cycle."
