Are you talking about video as in a DVD player or a streaming device? Depending on your remote, there should be a button labeled "TV/Video", "Source", or "Input". You press that button multiple times to go through the options. Now, your TV may not actually have an input labled "Video". You will probably have choices of different kinds of inputs labeled "TV" or "Antenna", "Cable", or types of ports, such as HDMI1, HDMI2, HDMI3. As you press the "Source" button to go through the sources just pause a few seconds (or you may have to press OK or Select) to watch each HDMI port to see which one your DVD is connected to. I hope this helps. Sorry, but there are many possible variations from TV to TV and different remotes.
SOURCE: magnavox universal remote for sanyo tv
ok...got this nice sanyo ds19310 from brother without remote..have a magnavox universal remote but don't have code for tv or if i can use magnavox codes or can i set remote to it another way...thanks for any help i can get! megnavox tv code is Press following key combination 0>6>2>5>9>6>MENU to select item press cursor(up)and (down) to change item value press cursor(right)and (left) cancellation of service mode press POWER button on the set regards thanks
SOURCE: PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Hope this helps :)
SOURCE: Programming a RCA Universal remote to a magnavox tv
Hi tinalynn1071
I couldn't find the book anywhere for you,but did find a guide on programming RCA universal remotes, and a list of standard codes you may wish to try:)
regards
robotek
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
SOURCE: DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
