Hi friend, thank you for your post!
Based off your post you are having trouble with frost on your rear wall and water dripping from the top middle section on the inside of your Frigidaire refrigerator. Sounds like you may have a possible problem with an air leak or water leak. I would suggest checking your seal to make sure there is no leak. You can do that by placing a dollar bill between the body of the freezer and door. If the bill comes out easily then the gasket may be causing frost to develop due to an air leak. I would recommend exchanging the gasket out. If the gasket is sealing properly then it could be an issue with the water line and you should perform a manual defrost that could help clear out any restrictions in your water line. To perform a manual defrost you would need to disconnect power from your refrigerator for roughly four to six hours. I hope this information is helpful. -Matt
Here
is a tip that will help you to find out why water will not come into
the dishwasher...
Dishwasher Trouble No
Water entering Dishwasher
heatman101
