This may be an option. http://pages.sewing-machine-manuals.com/173/PictPage/3923732159.html
Sometimes there is a 'vintage website that has free manuals, but i do not have the website.
Testimonial: "Thank you, didn't find it, but good to know."
SOURCE: making a buttonhole on a Necchi 3204 sewing machine
Here's what the manual says:
Before sewing, fit the button-hold foot to the machine (long white plastic thing with red, ruler like markings).
Select the pattern selector dial that is solid green on the left hand side. Set the dial to "1" position. Sew the left side and raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "2" position. Sew 5-6 stitches and raise the needle.
Select the pattern selector dial that is solid green on the right hand side. Set the dial to "3" position. Sew the right side. Raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "4" position. Sew 5-6 stitches and raise the needle.
Hope that helps...
SOURCE: manual fornecchi-alco sewing machine model 301
I have an ALCO 2200. Luckily I have the manual. If some one need the manual, I can photocopy and send it to you, if you do not mind paying the postage. :)
SOURCE: I need a user manual for a Necchi Alco 2200 sewing machine
Contact the individual who posted this answer.
SOURCE: necchi sewing 6030 machine manual
This is the only offering I could find - http://www.sewingstyle.com/necchi-6030.html
SOURCE: I have a Necchi 535 sewing machine and the thread tangles
if the thread under the fabric is a matted mess
1.the needle thread tension is to loose
2.needle is either to heavy or to fine for the thread
3.check to make sure the thread isn't off the thread take-up lever
Sharon, i’m sorry You didn’t find the manual. Did you click on the link i sent? I’ll resend it. It’s $10, i believe.
http://pages.sewing-machine-manuals.com/... I’ll also try to send a photo encase the link isn’t showing up. Sam
Ok, Sharon there is some question as to whether the Nelco is really a Necchi. There is a Nelco Alco A709 and there is a Necchi Alco A709. They look identical. Here is a link to a free copy of the Necchi Alco. I have a Neechi, so I downloaded a copy for myself, so give it a try. Sam.https://freenecchisewingmachinefiles.wee...
I did click the link you sent but did not find it, clicked this time and there it is - thank you so much.
