Hard Reset
1-Unplug the device and power off by holding the power button down
Wait 5 seconds, then
2- hold down both the volume up and power buttons (volume up is the side of the long button that is closest to the power button), until you see a screen with “Select Boot Mode” text on it. When you see that, release both buttons.
3-Press the volume up button to move the arrow until it is pointing at the “Recovery Mode” option, then press the volume down button to select it.
4-The “android” logo should appear for a few seconds, then you should be in the “Android system recovery” menu.
5-Use the volume up / down buttons to highlight the “wipe data/factory reset” option, then press the power button to select it.
6-Use the volume up / down buttons to highlight the “Yes — delete all user data” option, then press the power button to select it.
7-Once that has completed, you should be returned to the “Android system recovery” menu. Make sure the top option, “reboot system now”, is selected, then press the power button to select it.
8-The device should reboot and display the “android” logo, followed by the swirling coloured dots. You can then plug the device back in and wait for it to boot up. This will take a long time (up to around 5 minutes).
9-Once the device has booted back into the app, you should be able to set up the wifi, log in with your credentials and re-download your property data.
SOURCE: where is webcam lenovo g450
Make sure your camera is enabled by holding the Fn+ESC after doing so, try using the camera. if that doesn't work go to the link below and download the camera driver.
http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_list.aspx?CategoryID=880973
SOURCE: my lenovo t60 screen goes black 15 seconds after
Hi, try to boot into safemode, turn your system on then keep on tapping F8 to get the windows advance Menu screen, select safemode.
In the safemode windows go to Control panel and check your power options, you will see what time frame your system has for the LCD when turning off.
If this does not fix the issue, try booting into safemode with networking for you to be able to go online in safemode try updating your BIOS from your Manufacturers Website, Updating your bios may fix the issue.
SOURCE: Hi, The screen flickers at the
Hi techsyss,
I see that you are having issue with your taskbar flickering as you mentioned in the notes.
I would be more than glad to assist you regarding your concern.
>Try to reinstall your Video Drivers on the machine or poassibly update the Video drivers.
>Try chagning the resoltion on your system try setting it to a resolution that is lower than what you actually have and see if the flickering will still be occuring.
>Also try to boot into the BIOS of the machine to see if the Flickering occurs in BIOS as well, to boot into BIOS upon powering the machine keep on tapping F1 till you get a blue screen saying phoenix BIOS as long as the word BIOS is there you are in the right page. just check if the flickering happens there, if it does then the issue is not software but most likely hardware it can be the LCD itself or the Cable conenction of the LCD to the Video on the motherboard.
>if the flickering is present in BIOS most likely you will need to have the system serviced for proper repairs and diagnostics.
I hope this helps.
Have a nice day,
mvincentc
SOURCE: my lenovo LCD screen is
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thanks
SOURCE: need to reset user name & password for lenovo thinkpad x41 tablet
Windows Password Genius can help you to reset user and password at the same time.
