Hi Chris, indicate the brand and model of the TV you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Chris, indica marca y modelo del televisor que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
SOURCE: Pink cloud covering most of the screen
Lets bombard Hitachi with the pink cloud issue and get them to replace the TV or Fix it. I've got the same issue and the repair technician told me to fight for it. He wouldn't even come out to look, he knew right away what the problem was. The Red and Green engines were shot and said to scrap the TV. I told him that I just bought the unit in 2004 for 5000.00 and he said I'll have to fight for it.
SOURCE: sony wega KDF-42WE6 55
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
SOURCE: MODEL NO SP42W4HB PICTURE DISTORTED
This is most likely a convergence problem. You should see 2 large black ICs in side attached to a heatsink. They will be marked STK392-010. Try resoldering the pins on these ICs first. If that does not resolve the problem, replace them. These parts will be about $20 each.
Keep us posted.
Dan
SOURCE: Sony Wega - Pink Spots On Screen
You have a defective optical block. Contact Sony support and have your model and serial numbers handy. Sometimes they will warratny these even after the 1yr warranty has expired.
