Garden Logo
Anne Price Posted on Aug 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery-powered string trimmer cuts out
I have a Toro battery-powered string trimmer that starts but cuts out in less than a minute. I have cleaned it and made sure that the screens are clear. It was working fine until recently so I don't know what has changed for it to not run continuously.
Chris Walker
Level 3:
Top Expert:
  • Toro Master 1,573 Answers
  • Posted on Aug 18, 2019
Chris Walker
Toro Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1244930
Points
21965
5 Related Answers
Anonymous
  • 42 Answers
  • Posted on May 17, 2009
SOURCE: Husqvarna 324LDx 4 cycle string trimmer. Have
Probably needs a carb kit, check main jet and main fuel inlet jet, is the spark crisp, fat and powerful, try running it with a borrowed coil as this may have an intermittent fault. Is fuel cap breather working or blocked, these small carbs are very sensitive. Make sure all is well with gaskets and diagrahms. Good luck the Yeti
Anonymous
  • Posted on Jun 08, 2009
SOURCE: Craftsman 56''mower draining new battery rapidly-not recharging...
JUNK IT ITS A PIECE OF ****
Anonymous
  • Posted on Sep 22, 2009
SOURCE: Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Anonymous
  • 13 Answers
  • Posted on Apr 16, 2010
SOURCE: engine runs then quits
You may have a small air leak at the carb, sometimes found at the bulb primer. This allows the engine to stop picking up fuel due to sucking air into the fuel line. If you re-prime, it will run again for a short period?
Testimonial: "thanks for the quick and helpful suggestion"
Anonymous
  • Posted on Aug 27, 2010
SOURCE: Have a Toro 51990A string trimmer. It starts, but
toro trimer model 51990a part drum with eyelet
Toro 8 inch cut home duty trimmer how do you remove the spool
You have to hold in the two tabs at top of spool assembly
1helpful
Gettin spool off to change string
1.Twist the cap off counterclockwise.
2. Remove the cap and spool.
Note: If the spring falls off, install it before installing the spool.
3. Thoroughly clean the cutting head and cap and inspect them for anydamaged or worn parts.
I dont know what string to use in my toro 8" battery trimmer
The thinner string works well in these machines and puts a lot less strain on them. I would suggest using a string of .065 range. The thicker (and more expensive) string used in the gas machines is too heavy for these lower powered electric units.
2answers
2helpful
5helpful
2answers
Case won't opem
There is a screw underneath the Toro label.   I learned the hard way.
String breaking
Check to ensure that the string is the correct size as specified in the owners manual. If ok check age of the string. If old it has a tendancy to be brittle. If new and supple try letting the trimmer get up to full speed and let the tip of the string do the cutting. Avoid taking on too much at once with this trimmer as the electric and battery trimmers are not as powerful as their gas counterparts. I hope this helps.
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
