Radio Communications Logo
Ine Dijkstra Posted on Aug 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The weather guy from channel 15. - Radio Communications
RudeRude
Level 3:
Master:
  • Master 526 Answers
  • Posted on Aug 18, 2019
RudeRude
Master
Level 3:
Master:
Answers
526
Questions
0
Helped
138446
Points
1635
What about him? He always gets it wrong.....
1helpful
I have direct TV but I can not get my local weather any more or my families weather by zipcodes
DirecTV carries two national weather stations: WeatherNation on channel 361 and The Weather Channel on 362. Both have an interactive component for obtaining local weather. Depending upon your remote, those functions are reached either by the Red button or by the Active button.
Display station not showing outside temperature
Check battery status indicator on main weather station of remote unit. If no indication, replace battery in remote unit. If battery is good then check "channel setting" of remote unit to make sure the channel setting on remote unit matches the "channel" setting on main unit. many weather stations will take up to 3 or 4 remote units and they must use different channels to relay the remote imfo to the main weather station unit.
Weather chanel comes in costanty
Cannot have a regularly scanned channel be a weather channel. press 'manual' on the WX channel, then press the 'L/O' "lockout" button and it will keep the WX channel out of the scan.
Cant get weather on my motorola MH370CR
Setting the Weather Channel
Your should radio receives weather frequencies if you are close enough to a reporting station:
1. After turning weather reception on, press . The current
Turning Weather Channel Reception On and Off
1. To turn weather reception on, press and hold + (plus) for three
seconds.
2. To turn off, press + or turn the radio off and then back on.
Your radio receives weather frequencies:
1. After turning weather reception on, press MENU . The current
channel flashes.
2. Press + or - to select the appropriate channel with good
reception in your area.
3. Press PTT to save the weather channel setting.
Here's a link to the MH user guide.
Best regards.
http://www.motorolasolutions.com/web/Business/Products/ConsumerTwo-WayRadios/Talkabout-MH230R-Two-Way-Radio/_Documents/MH230.pdf
Which is better? The Weather Channel Vs AccuWeather for iPhone
While AccuWeather is better looking and has more of a Mac-feel to its interface, The Weather Channel app trumps it by offering more essential information in an easy-to-access manner. The Weather Channel is a free download in the iTunes App Store.
Sep 06, 2010 • iPhone Apps
Best weather apps out there. Any idea guys?
'Weather Channel' Being the No. 1 free weather app in the App Store comes with a bit of scrutiny. But what can I say? They are The Weather Channel, and they know what they
MY RADIOSHACK NASCAR PRO-84 SCANS THREW CHANNELS BUT STAYS STUCK ON ONE CERTAIN WEATHER CHANNEL AND WONT CONTINUE SCANNING AND I NEED TO NO HOW TO DELETE THAT CHANNEL COMPLETELY.
The NOAA weather frequencies have constant broadcasts, so your scanner "locks" onto them. The only ways to prevent this are to either delete the weather frequency or lock it out. To delete, just program the frequency "0.0" (zero point zero) into the channel. To lock it out, press the L/O key while on the weather freq.
Bill B
1helpful
Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
"Weather Channel" OVERWRITED "OPTIONS"!
try going to the weather channel or send your wii to nintendo, it may just be a simple error, but i've never heard of such a problem before. You may want to consult 1-800-255-3700 (nintendo consumer service) for help
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
