SOURCE: hi! I have a problem
You have tried re-setting it, Right?
What happened when you did?
Note: This problem ended up under Vacuum cleaners-
You might want to try re-listing it again-- under Electronics?-
Mack B
SOURCE: Hi i have a rca Clock Radio RP5435C i need to know
Move the switch on the top back to either the clock symbol to set time or alarm 1 or 2 depending on which one you wish to set. On either side of the snooze button is a fwd and rev button. Push fwd to advance the time or rev to go back. If setting the alarm it will automatically turn the alarm on when you set it. To turn alarm on or off manually, push the button for the alarm you choose on the top rear right side.
SOURCE: I have a RCA clock
if the clock radio is coming back on without being plugged in or still has the time on it when plugging it back in, it probably has a backup battery, take the battery out. Why can't you just reset the time to the correct time, just push the time set button, then the hour button, etc.
