Cell Phones Logo
C
Charles Muhammad Posted on Aug 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reset lhb336 - Cell Phones
Chris Walker
Level 3:
Top Expert:
  • Cell Phones Master 1,573 Answers
  • Posted on Aug 18, 2019
Chris Walker
Cell Phones Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1245499
Points
21965
Master reset with hardware keys
  1. Back up data on the internal memory.
  2. Turn off the device.
  3. Press and hold the Power and Volume down buttons on the back of the device.
  4. When the LG logo appears, release and then re-hold the Power button while continuing to hold the Volume downbutton.
  5. The Factory data reset screen appears.
LG LHB336 Home Theater System (Blu-ray Player, Receiver). My LHB336 is shutting itself down after few minutes.
Well you have covered the main two, overheating and failing capacitors. The only other one I can think of is a component / IC dry joint on the circuit board. As the board heats up, the connection fails. Or something is failing internally when heating up.
tip
Restarting and Resetting iPad
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears.
If you can't turn off iPad or if the problem continues, you may need to reset iPad. This should be done only if turning iPad off and on doesn't resolve the problem.
if the problems still not resolved Reset iPad settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media aren't deleted.
Reset all settings: Choose General > Reset, then tap Reset All Settings.
Reset network settings: Choose General > Reset, then tap Reset Network Settings.
Reset the keyboard dictionary: Choose General > Reset, then tap Reset Keyboard Dictionary.
Reset the Home screen layout: Choose General > Reset, then tap Reset Home Screen Layout.
Reset the location warnings: Choose General > Reset, then tap Reset Location Warnings.
4helpful
2answers
Boot and please wait problem
I had the same issue twice (2 diffrent devices) on LG Blue-ray HX-906 - stuck on "please wait" after switching it on. It turned out to be defective mainboard - main BGA chip (the one with black radiator) has some problem with connection to mainboard. Here is how to repair it:
- dismount the mainboard
- take off the radiator from the main chip
- put alluminium foil around the chip to avoid unnecessary heating up of other parts of PCB
- heat up the chip using air hotgun to about 200 celsius for about 5 minutes.
Mount everything in reverse order and enjoy
Lg network 3d blu ray home theather model# lhb336 problem/boot and please wait
Check working condition hardware. May be malfunction Main Boar or AMP. Unplug cable (wires) attached from Power PCB Board and main board to AMP PCB Board. Turn ON, if again comes message " Please wait" and unit sot down itself- Malfunction main board. If unit booted UP -OK -replace AMP board. Parts are available on our web
Where can i fine the serial number
in the back of the receiver on the white sticker next to the RGB connectors
1helpful
I installed a HDMI cable and an Optical cable to whatch movies and shows from my LG HD LCD TV, but nothing seems to work. The stereo is also a LG LHB336 system. Which is compatible with the TV. We were...
Hi,Even though you have done some cabling already,for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
