I was not able to get a free unlock code for the mobile model that you have specified. suggest you can approach Superunlockcodes.com and specify the country,locked network of Samsung 870A .Based on the availability you can get the permanent unlock service along with free instructions.
I had the same problem. Seems the little gizmo in the base that pushes up the water release valve is set a bit too low. With the water tank removed, you'll see a plastic circle with a plastic "x" in the middle. A tiny drop of glue on the "x" to raise the level a bit did the trick for me.
YOU HAVE TO UPGRADE THE FIRMWARE IN THGE Canon camera. IT is on the SD card that came with your microphone. Insert SD card and tell it to read - it will update firmwaree and then connect 5.1 microphone
