SOURCE: Boston Acoustics Digital BA735 Speakers with no Analog input.
I use one set of BA735 with two computers. Computer A sends digital out
and Computer B sends analog. BA735 plays both. I listen to music using
digital while the analog from the other computer alerts me to the
incoming messages in Pidgin.
I did have to change bios settings on one computer to use the on-board audio.
To enable digital output in XP, click on the speaker icon > Advanced
> Select Enable SPDIF. You can leave the PC Spk Mute unchecked if
you want the analog output as well. That's all.
I hope you are able to enjoy the rich sound of BA735. It's beautiful.
My ears thank a lot for replacing those desktop speakers. BA735 hardly
takes up any space . Two small speakers are perched on the hutch and
the bass module is somewhere behind the desk, completely invisible.
SOURCE: kenwood vr-5900 no sound
Check you settings on the receiver. get into the menu of the unit and check the "Audio" settings. if you can choose by specific input, select "Digital" otherwise, select "Auto" that should correct the problem. If you still have a problem, post a comment and I can help you troubleshoot some more.
SOURCE: HDMI input 1 with Analog Audio
In the audio menu there should be a setting for which audio you are using. JVC loves putting different options in there audio menu.
SOURCE: Digital tuner stopped working. Analog tuner works fine.
I have the same problem. I checked with Philips and they told me to take it to a local shop. If you get a solution please let me know.
After system boot-up, hold a right mouse click
button and there will be login window. Hold a left
mouse button to click the order of "Account", and
input correct account. Then left click the order of
"Password" and input correct password. At last
left click "Login" to enter system. There is one
factory-preset login "account/password"
"admin/111111" at admin level. The user can
use it to login the system for the first time
