Question about Refrigerators
Compressor has no power to it. coil shows 4.6 on an ohm meter. will not engage when jumped. 1992 gmc sierra pickup k1500 harrison compressor
    Top Expert:
  • Refrigerators Master
  • 1,533 Answers
Posted on Aug 18, 2019
SOURCE:
  • 1118 Answers
SOURCE: Replace starter on 1992 GMC Sierra pickup truck
First thing unhook positive battery cable, unhook main cable on starter selanoid and small wire on selanoid (there may be 2 small wires) There may be a bracket on front of starter that has to be removed, and then the 2 main bolts that hold it to engine block and it should come out.
Posted on Feb 14, 2009
SOURCE: 97 gmc sierra no fuel no spark replaced ign module
1996 GMC 1500 Pickup.
Replaced Coil, Dist cap/Rotor, Ign Mod & pick-up.
All showed to be bad with OHM meter.
20A ECM-B fuse keeps blowing out and I'm afraid to burn these new parts up....
ANY IDEAS OUT THERE???
Posted on May 19, 2009
SOURCE: 1992 gmc c1500 ac compressor relay location
I pulled this from another web site
"The AC clutch relay is located inside the cab on a metal bracket that is easiest to see when you remove the glove box compartment.
The relay is on a metal bracket bolted to the top of the plastic air box, forward and to the center of the dash from glove box.
There are three relays in a row on that bracket. The AC clutch relay is the end one closest to the driver’s side."
Posted on Aug 18, 2009
Testimonial: "Right on target... THANKS"
  • 6 Answers
SOURCE: I need a wiring diagram for a 1993 gmc sierra 4x4
I found my diagrams at outo zone.com
Posted on Aug 30, 2009
  • 22331 Answers
SOURCE: 1997 Gmc Sierra fuel pump relay has no power
check fuse and fuse panel connections
Posted on Oct 29, 2009
How do I test the actuary switch used to engage the front axle for a 1996 GMC pickup with 4 wheel drive
Not sure if you mean the switch or the actuator. The switch can be tested with a test lamp or ohm meter, while the actuator will likely have to be removed and inspected.
Feb 18, 2015 | 1996 GMC Sierra
Where is the pickup coil locate on a 1992 gmc suburban k1500
it should be on the right side toward the back of the motor
Sep 09, 2014 | 1992 Chevrolet K1500
Had a total power failure in my 92 GMC pickup. Truck died like some one flipped of a light switch. Any clue?
1) timing chain
2) alternator system
3) chargin system see the chart attached.
God bless you
Sep 28, 2012 | 1992 GMC Sierra K1500
Where to find diagram to install whole rear brake lines on 1992 GMC Sierra 1500 series pickup truck
I don't know about a diagram. Just buy some 1/4 inch brake line and run it as close to the original as you can.
Apr 03, 2010 | 1992 GMC Sierra K1500
92 gmc pickup,fuel injected throttle body.Engine intermittently cutting out.Changed coil but problem persists. Any advice would be appreciated. Don.
electronic dizzy modules do this when they get warm they cut out but can start up again within minutes !
very commen fault!
get it checked or borrow one
Cheers Rob
Aug 15, 2009 | 1992 GMC Sierra K1500
No power to distriutor
I would check ignition coil. Maybe it is outside or inside the distributor.Check rsistance. Get ohm values from a haynes/chilton repair manual(i do not know them)NOTE DISCONNECT BATTERY to check resistance. check condenser(capacitor)inside or close to distributor.
Jun 14, 2009 | 1992 GMC Sierra K1500
Air Conditioning
If you have no power (12v) to the power wire at the A/C compressor clutch and have jumpered all of the switches then you need to check for power coming out of the A/C switch on the dash. Also there might be a pressure switch on the back of the compressor that you can jumper also. You can also check A/C compressor relay in the under hood fuse/relay box. There might be a fuse in the under hood fuse/relay box for the A/C too. Hope this helps.
Apr 23, 2009 | 1992 GMC Sierra K1500
97 gmc sierra no fuel no spark replaced ign module and pickup coil still no spark
Mar 31, 2009 | GMC Sierra 1500 Cars & Trucks
Engin light on
Well, if it's not getting gas have you confirmed power and ground to the fuel pump? If you jump the fuel pump relay does it star?
Dec 28, 2008 | 1993 GMC Sierra K1500
4 x 4 problem
Depending on weither you engage it by a button or a lever, i can help you. For the lever engagement you just make a complete stop, fully pull the lever into 4 high, and drive the vehical backward and foward several times. If you have problems with the button engaugement, it could mean you have a vacuum leak.
Dec 13, 2008 | 1992 GMC Sierra K1500
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
