2004 Oldsmobile Alero Replace windshield wiper motor ...
www.fixya.com > ... > Oldsmobile > Alero > 2004 Oldsmobile Alero Get solutions for 2004 Oldsmobile Alero replace windshield wiper motor ... The problem is often just a clog in the sprayer heads. ... ...windshield wiper fluid, I hear the pump's motor running but no fluid is ejected. remove the hose from the wiper .
Should be able to purchase sprayer head only at any store that sells taps and hardware to go with them. I got a replacement at a plumbing store in Chatham Ontario.
The A11218-1 is merely a plumbing standards number. Look further to try and find a manufacturer name or model. Or take it into a local professional plumbing supply store.
Try disconnecting the tubes from the spray head (under the hood). The press spray button, if nothing comes out, you have a bad pump. It liquid is pumped, then you need to clean or replace the spray heads - they are clogged or damaged
minarl deposit bildup in the handol best to just replace the sprayer any hardwer store hose is still good only sprayer head needs replaced comen threds
unfortunately this is a common problem with sprayer heads, check the rubber gasket for any defects and also check the gasket seat on the sprayer end and the supply line end for any debris or defect. sometimes the only way is to replace the sprayer itself.
Check for a leaking O-ring/Washer/Seal and replace. Sometimes the internal parts of the sprayer head will wear out. Replacement sprayer heads can be obtained from your local hardware store.
I'll look forward to hearing back from you. :-)
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
