Televison & Video Logo
d
david gee Posted on Aug 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a fuse on the NAD 701---
Turn on then the lights and power go off --- no sound
Ed Cole
Level 2:
Habit-Forming:
New Friend:
  • Expert 123 Answers
  • Posted on Aug 18, 2019
Ed Cole
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
123
Questions
0
Helped
23784
Points
265
Disconnect all the cables from the power supply Board and measure the output voltages. Connect the cables back one at a time powering down between each one and see what is dragging the power down.
My NAD C372 integrated amp was working normally everyday. One day, on pushing in the "Power On" button, it did not light up. No response at all.
It could be anything from a blown fuse from a power surge to a shorted capacitor ijn the power supply. There are fuses in all amplifiers. Locate it and test it with an ohmmeter.
I get no sound from my nad t175 preamp connected to a nad t973 (7 ch.) regardless of the media - rca, hdmi, et al. The fuse in the amp is fine, all the lights are working. Regarding the t175 i can see...
Possible that the amplifier has tripped and so gone to a protection mode. Remove power for few hours, press down all panel switches to drain off voltage from the processor. Also check for any short on the speakers before it is powered on.
NAD C521 on / off button light
"POWER ON: Press this Green button to switch on the power to the disc player from Standby mode. The LED will change from Amber to Green, and the EFL display will illuminate."
So besides the L.E.D. the unit has another visual indicator that it's turned ON, the display lights up. Is this worth pursuing a fix?
3helpful
2answers
I have a NAD 510 CD player with no display lighting working and would like to repair this myself, and also a NAD 710 receiver/amp that does not tune in any stations but otherwise works fine, would it do...
wont do any harm to open it up. look for blown fuses. i have a NAD amp and the desplay goes blank and sound distorts when there is a blown fuse inside, my amp has abourt 8 fuses inside it 4 per chanel
Nad c 370 no power
You need to look inside. There will be a fuse inside too. If your lucky it will restore the amp once replaced, but if it blows again you have a fault. You can track it down yourself if your any good, you might even see a burnt out part when looking for that fuse, otherwise get the repairman in.
Nad 310 no power
The output should be 24v ac. Sounds like you have a busted transformer. Did you check out the resistor in front of the transformer.
You sound like you know what your talking about so I will not bore you with suff like glass fuses and thermal couples.
Good luck, I have had a few items like this over the years. Sometimes it's just best to send them in to the manufacture. I would look for a replacement transformer. 120v ac to 24v ac around 5 amps. Test it out and see if it works... If not, send it in.
No power at all on NAD C370
User manual here
http://nadelectronics.com/img/manual/NAD-C370.pdf
Read page nine for some simple troubleshooting tips and see if that helps.
It *could* be a fuse but given you've owned it for a while and NAD amps often have capacitor issues in the power supply, chances are it needs some serious work by a good tech. Contact NAD directly and see what they recommend.
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
2answers
Nad amp failure
Check fuses mounted near transformer . If blown check output transistor. Also check transistor transistors on small heat sink . they will cause fuse to blow.
Top NAD Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Larry
Are you a NAD Televison and Video Expert? Answer questions, earn points and help others
