SOURCE: whirlpool ultraease warm on left side, dispenses warm water
not dangerous, i would recommend vacuuming coils under and behind refrig, make sure the fan behind the unit( cooling for compressor) is running full speed. the water is probably "warmer" then usual because the waterline runs across the bottom of the refrig, which appears to be overheating as it is. this should rectify your issue
SOURCE: Amana Side-by-Side Refrigerator Not Cold
can be a few things, if you open the freezer door do you hear afan running?? perhaps the fan is no good?? is there a large amount of frost on the lower plate of back wall of freezer??? very common issue to have a bad defrost thermostat.
SOURCE: my kemore side by side is luke warm as of this morning.
Sears gives their models different numbers for example 198.215478
Look for the number so I will be on the correct model and help you better.
Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
im sorry to tell you, but the sound is probobly normal.
fridges these days make some weird noises.
they started making noises when they changed the gas to R34a.
you may be able to get a noise ruduction kit for your model. they are not too fun to install
SOURCE: Outside door seams are hot to touch
This is because the mullion heaters are on. This is a system designed to dry up sweating that occurs on the outside of the box in high humidity. Check to see that all the door seals are tight.
