Vacuums Logo
L
Larry seibert Posted on Aug 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I own a slim ball upright dyson vacuum cleaner and was wondering what the little door is for that’s hidden by the top of the ball?
  • Terry
    Terry Aug 18, 2019
    Dyson web site has many models, so if you can identify it here, a manual can be downloaded.
  • Peter Wrightt
    Peter Wrightt Jul 23, 2021
    It is to remove filter
Thomas Perkins
Level 3:
  • Master 15,088 Answers
  • Posted on Jul 23, 2021
Thomas Perkins
Master
Level 3:
Answers
15088
Questions
0
Helped
3389630
Points
54869
5 Related Answers
ukvacfan
Ryan S
  • 328 Answers
  • Posted on Apr 12, 2009
SOURCE: where is the belt on a dyson upright vacuum?
There is no drive belt on this model - its a cylinder pull along model.
If there's a problem with the turbo brush you can flip open the base of it by removing the screws, check that the toothed belt is in place and there is no clogs of dirt between the turbine and the brush bar.
Anonymous
  • 71 Answers
  • Posted on Jul 19, 2009
SOURCE: Dyson - Ball HEPA Upright Bagless Ultracompact and
Hi have you checked underneath to see if the belt has snapped, you will find it either side of the brush, if so you can obtain a replacement at most retails stores but take the model number and make with you, hope this helps
Anonymous
  • 5 Answers
  • Posted on Aug 12, 2009
SOURCE: dyson 18 losing suction
Check the HEPA filter if it has one. This bit of foam gets clogged over time and significantly reduces the suction especially if you've been vacuuming a lot of very dusty areas i.e. dust from building work etc. Just wash the filter with lots of water and leave to dry before reinserting.
Anonymous
  • 438 Answers
  • Posted on Apr 11, 2010
SOURCE: Dyson DC07 Vacuum Cleaner
It sounds like to me that you probably have a clog in the hose port, or that your attachment hose may have a hole in it. Both of these problems are common problems on the Dyson DC07 model.
The first place you should check is the clog part that's directly underneath of the hose. Pull this port out and see if you can see anything lodged inside the clog port:
If you aren't able to find the clog here, then pull the wand and hose out of the vacuum. With the vacuum cleaner off, pull the hose out as far as it goes, and inspect the entire hose assembly from the end that the wand connects into, until the end that fits into the vacuum itself. A lot of times this hose will tear due to the sharp end of the wand as the hose is being pushed back up the wand.
If neither of these solutions worked, please just use the clarification request form here on the Fixya repair page, and I'd be happy to do some more advanced diagnosing with you to figure this out.
If this was helpful to you, please help other Fixya users find this answer by rating the repair helpful, by clicking the thumbs up icons in the top right hand corner of the repair.
Thank you very much,
Chris J.
GoVacuum
joneeboy
  • 66 Answers
  • Posted on Jul 10, 2010
SOURCE: how to replace electrical cord on Dyson ball
Depending on where it has been chewed, you may not need to replace the whole of your cord. Ask your local electrical supplier, or possibly somewhere like B & Q, if they have an 'inline' plug and socket to repair your existing cord.this would resemble the type of plug and socket used to connectd the power chord to a lawnmower, except you would not be buying the sealed type.Then you could simply cut out the chewed part of your ccord, and fit the two new ends, one the plug and the other the socket.It is no more difficlt than fitting a new domestic 13 amp plug on a cable.It is also a safe but much cheaper solution, so you should save money too.
Dyson Cinetic™ DC77 Multi Floor Upright Vacuum, Flipper valve not working properly, flips good for the top , but not the bottom
I would try for spares at a Dyson service stockist.
https://dysonvacuumspares.co.uk/dyson-dc75-dc77-cinetic-big-ball-animal-vacuum-cleaner-spares
2answers
The seals on my dyson ball have broken loose in a couple of spots and prevents the ball from rolling freely
How old is your Dyson?
I suggest you contact Dyson Support directly to see what they can do for you. Make sure to have your model number and Serial number handy when you contact them.
Here's the link to their main page; once there, click on "Support" Dyson vacuum cleaners fans heaters accessories spares official site
Dc dyson 24 free repair maule
About 1,100 results (0.84 seconds) Search Results
    Dyson DC24 - Resetting the brush bar (Official Dyson video ...
    ? 1:55
    https://www.youtube.com/watch?v=akGLQ7UbctY
    Sep 29, 2011 - Uploaded by AskDyson
    DC24's brush bar is engineered to shut off for protection if something jams i. ... How to clear and reset the brush bar of yourDyson DC24 upright vacuum cleaner ... Dyson DC24: How toRepair a Loose and Clunky Ball. ... Dyson Ball DC 25 not locking beater bar brush in place while upright - Duration: 17:09 ...
    How to fix your Dyson Vacuum Cleaner when it loses ...
    ? 7:45
    https://www.youtube.com/watch?v=0vd3ldLXgI4
    Apr 16, 2013 - Uploaded by Chuck Fresh
    How to clean the two filters in your Dyson Ball or Animal Vacuum... troubleshooting computer problems, pc helpline, free pc repair... How to take apart Dyson DC 17 to Clean and Service - Duration: 14:33. n4ktz 178,332 views ... Dyson DC24 - Resetting the brush bar (Official Dyson video) - Duration: 1:55.
    [PDF]Dyson DC24 Manualhttps://www.dyson.co.uk/.../Dyson/.../Manuals/DC24_Manual.pdfDysonNote your serial number for future reference. After registering for your 5 year guarantee, your Dyson vacuum cleaner will be covered for parts and labour for.Dyson DC24 Manual - ManualOwl.comhttps://www.manualowl.com/p/Dyson/DC24/Manual/112339Manuals and user guide free PDF downloads for Dyson DC24. ... I Have A Dyson Dc17, Is There A Fuse Or Reset Button On The Vacuum Motor ... Complete Dyson customer service phone numbers and contact information at ContactHelp.com.Dyson DC24 Multi Floor Instruction pack - Part 914529-01 ...https://www.dyson.com/parts/u/user.../dc24userguide.aspx?...DC2...DysonDyson DC24 Multi Floor: Instruction pack - 914529-01.Buy genuine parts and accessories direct from Dyson.DYSON DC24 USER MANUAL Pdf Download. - ManualsLibwww.manualslib.com > ... > Vacuum Cleaner > Ball DC24Page 2: General Safety Precautions. Do not use with damaged cable or plug. If the supply cable is damaged, it must be replaced by Dyson Ltd, our service agent ...
2helpful
Dyson dc40 won't stay upright
Hi Wendy, it's Jack at Dyson.
Our current generation of Dyson Ball upright vacuums uses a pedal-free stabiliser mechanism. When you've finished using the machine, stand it upright firmly. You should hear two clicks - the first is the suction changeover valve redirecting the suction to the hose and wand. The second click is the upright lock mechanism securing the body in place.
As long as you've stood the machine up firmly enough, you shouldn't have any difficulty with it not remaining upright - this may take some getting used to if you've previously owned a vacuum cleaner with a pedal-based system.
If you would like any further help with your machine you can reach our experts directly by calling the Dyson customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1800 239 766 (AU).
My dyson roller ball upright vacuum cleaner will not go upright? you push the red bar to put the vacuum down to clean and then it won't go upright again?
Hi there, Sorry to hear you're having difficulties with your Dyson cleaner. I wonder if your cleaner is actually a DC25? If so, it's possible that the stabiliser pedal has become misaligned. However, if you do have a DC24 and are having trouble standing it upright, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week. Kind regards, Jack Dyson Online Customer Support
I received a NEW dyson ball vacuum for Christmas. I have noticed when I vacuum with it that dirt collects all over the ball and the vacuum beater head. Is this normal. I have had the regular upright...
This may sound silly, but it sounds like that you a have static electricity problem. If the dust is collecting on top (outside of the brush head that is probably the static attracting it. This is common during the colder months. You know how during these months when you walk across carpet and then just someone or a metal objest, you get a shock.
You might try lightly spraying a little "static guard" on the top of the brush head before using it, or using a carpet dusting product that smells good, and may reduce the static.
5helpful
2answers
After hoovering yesterday my dyson ball wont stand up right.
solved this today by folding the upright part back as far as it would go, and wiggling it a little. It clicked back into place.
8helpful
3answers
Beater bar on Dyson upright won't turn when handle is lowered
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
