Microwave Ovens Logo
QuocAn Long Posted on Aug 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I remove the control panel? - Cuisinart Microwave Ovens
Tom Chichester
Level 3:
Top Expert:
  • Cuisinart Master 62,329 Answers
  • Posted on Mar 12, 2021
Tom Chichester
Cuisinart Master
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
672158
Points
975369
The outer cabinet has to be removed to gain access.
5 Related Answers
VEKAT
Devabhakthuni Venkateswara Rao
  • 225 Answers
  • Posted on Sep 24, 2007
SOURCE: Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 17, 2007
SOURCE: User's Manual of Sharp Microwave Oven Model R-9H56
Found this posted under Whirlpool instead of Sharp, but I'll be happy to answer it here.
While that one may not be available, we have one that may be close enough to work:
http://www.microwavedisplay.com/r9h66_r9h76_r9h84b_r9h94b_om.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 27, 2008
SOURCE: GE Microwave Keypad or Control Panel
If some pads on the keypad are not working, then you have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
On this model, the cover will have to come off to replace the light bulb. If it's mounted in the wall, it will have to come down.
The installation instructions are nice to have in this case. You can download GE owner's manuals and installation instructions here.
I have attached a drawing to show where the bulb is on this model. It is located on the right side of the oven next to the wall of the cooking cavity.
The bulbs are available in local grocery stores, hardware stores, and stores like Wal-Mart and Lowe's.
Please feel free to contact me directly if you need more help.
William E. Miller
[email protected]
Anonymous
  • 3 Answers
  • Posted on Nov 04, 2008
SOURCE: does microwave ovens make noise while it is in process of heating?
It seems like it is the first time you either own or using a microwave oven. Yes, there are more than one fan/motors inside a microwave, depending upon the model/type.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 09, 2008
SOURCE: wolf - microwave oven not turnin ON
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
1helpful
How do I remove the front control panel on a ge profile je2160sf01?
On most over the range ovens, the screws for the control panel are on the top of the control panel. You usually have to remove the air deflector above it to acccess the screws.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
1helpful
How do I remove the control panel
Main door lifts off. Look for screw under vent panel at top. Remove vent panel to find screw (s) holding control panel.
How do I open it up to look for a blown fuse to circuit breaker?
When you remove the front control panel you will see the two fuses in the next internal section. Below are instructions for removing control panel:
You can do this without removing unit from wall. First unplug unit. Next remove the two screws on the top of the unit closest to the front. These screws simply keep the up facing vent in place. Next slide the vent to the left (plastic latches on bottom hold in place) to allow vent to be removed. You should now see a single screw above the control panel. Remove it then open the microwave door. Gently slide the control panel up which will disengage the plastic latches on the panel sides. Suggest if you are going to remove the controller and replace take a picture before removing it so you know exactly how to reconnect all the wires.
How do i remove the control panel
Hi Colin, On our microwave , unplug first, husband just removed thewhole outer casing of microwave and pushed the button through the back, he did not touch the control panel. Hope this helpskind regardsChristine
Panel problem
Hello
Unplug the microwave from the wall outlet prior to disassembling.
Open the microwave door. Remove the screws securing the grill above the door opening to the microwave. Remove the grill.
Remove the screw located at the top of the control panel, which is now visible with the grill removed.
Lift the control panel up to release the tabs securing it in place. Move it away from the microwave.
Look at the rear of the control panel to any disconnected wires that may have caused the control panel to stop functioning. If wires are disconnected, reconnect them, reassemble the microwave and determine if the problem is still occurring. If the problem still occurs, replace the control panel.
Transfer the wires from the old control panel to the new control panel.
Move the panel back against the microwave's control panel housing. Slide it down to lock it into position.
Install the screw at the top of the control panel.
Replace the grill on the top of the microwave. Secure it using the screws that were removed.
Restore power to the microwave.
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
6helpful
Sharpe Microwave R-316F Display Light
first remove the outer cover by removing the screws at the back.then u should see a screw behind the control board that holds it.remove that screw and the control board comes out.disconnect the wires from control board and remove remove the panel assly.then remove the screws that hold the control board to the panel.
I have a new control panel to fit to a Panasonic NN-T790SF Microwave oven I need to replace. I don;t know how to remove the old one.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Basic disassembly on this is as follows:
1. Unplug it from the outlet.
2. Remove any screws and unlatch any tabs in the vent grille.
3. Pull up and/or out to remove the grille.
4. Remove the screw now revealed at the top of the control panel assembly.
5. Lift up and/or swing down the control panel assembly.
William E. Miller
[email protected]
1helpful
Advantium oven # SCB2000/2001 F3 beeping (replace touch pad) - How?
F3 on a GE / Hotpoint microwave means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved in standard models.
Here are specific details on your model:
To replace the control panel, you will need to remove the microwave from the installation. You will also have to remove the top access panel.
Before removing the microwave from installation, disconnect all electrical power to the oven by turning off the appropriate electrical breaker.
Here are the steps for removing the control panel:
1. Remove the oven from the cabinet or wall opening.
* CAUTION: Do not use the oven handle to lift or lower the oven. Damage will occur.
* Be careful that electrical conduit is not caught or stressed during removal.
* This step requires 2 people for removal. The microwave should be grasped from the bottom and the front and rear of each side during removal.
* Remove the 4 mounting screws located in the front oven frame.
* Carefully slide the oven forward and out.
* Lower the oven onto a protective surface for servicing.
2. Remove the top access panel. There should be 9 screw attaching the top panel.
3. Disconnect all connector plugs on the control panel. CAUTION: Be sure to note the location and routing of wires for proper reinstallation purposes.
4. Lift the control panel to disengage the lower hinge tabs from the chassis.
5. Remove the control panel.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
3helpful
GE Microwave JVM3660SD001 Control Panel Removal Procedure
Remove the grill, should be screws on the top of the unit. There should be one screw behind the grill at the top of the control panel. Remove it and pop the control panel up to remove it. Make sure the mw is unplugged first. Then you can remove the board.
Top Cuisinart Microwave Ovens Experts
vince
NOEL
NOEL
john h
Are you a Cuisinart Microwave Oven Expert? Answer questions, earn points and help others
