SOURCE: path key #1234 not working
The Motorola krazer phone is not on the compatibility list. The only Motorola RAZRs on the list are the V3, V3i, V3m, and V3x. Check the outdated list at http://www.kenwood.com/bt/bt100/
SOURCE: motorola h700 pass key
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H700 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
SOURCE: unable to copy files to cd
sounds like the optics in the CD drive have bit the dust. replace your drive. you can get one for cheap at any computer store
SOURCE: error message
GO into tech mode by pressing "menu" then #1934
once in tech mode press #10 and scroll through the menu with the arrows until you come to printer cartridge. Select that it is a new one and then your error will go. To exit tech mode do the same - press menu then #1934
