SOURCE: Directv code for westinghouse LD 4055
Follow these steps:
http://support.directv.com/app/answers/detail/a_id/3188/~/white-remote-control-programming-steps
When it asks you to enter the code for your tv use 10178
It works like a charm!
SOURCE: Is the westinghouse LED TV LD 4055 ARC compatible?
I don't believe it is. Westinghouse mention nothing about it in the Manual. However, whether it is or not, it won't make a difference in the sound system you buy. If you get your cable feed from the TV's tuner you can connect the Digital Coaxial output from the TV to your new HT receiver.
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
