SOURCE: Braun Series 7 760cc dead after 2 months
Had this same problem with mine. One month after warranty was done with. I ended up opening the thing up and pulled the monster battery out of its socket and put it back in. Worked fine after that. One week and still strong. Another thing I did was to carefully bend up the flat pieces of copper around the battery to make sure they were still getting a good contact with the pins on the cover. Hope this works for you....
Also... I am not responsible for any damages that may occur.
SOURCE: My Series 7 790cc razor became really loud after a
Your shaver came with a 2 year manufacturer warranty. Follow the warranty istructions in the user manual that came with the shaver or call Braun at 1-800-272-8611
SOURCE: my husbands braun series 3
Make sure you are positioning the shaver on the station properly and press the clean button.
Thanks
SOURCE: We cannot find the directions
You will find the user manual for Series 7 shavers at shaveroutlet.com. Click on the link below
http://shaveroutlet.com/shavers/braun-790cc-series-7-pulsonic-shaving-system.html
When the item page opens, click on 'user manual' just below the item price
I wonder if you can charge the shaver with the cord. Or is the battery dead?
Please also check if the blades of the shaving head are pressed on correct. It is the cleaning system, what pumps up the fluid, and after a while is the the shaver that should start pulsing. So it must be an error with the shaver. If the shaver works normal but does not when not in the cleaning station, also check the contacts on the shaver and on the cleaning station.
