Question about Exercise & Fitness
I cannot connect my Fitbit Surge to my computer Mac and the time on the fitbit is wrong.
SOURCE:
elix0411
  • 3530 Answers
SOURCE: I have worn my fitbit
Welcome to Fixya
Fitbit common issue is it will die right away if it gets wet. You may try to force reset it by docking it and then holding down the reset button on the bottom with a pen tip or paperclip. The screen will flash with your current firmware version and the battery level. If this will not work then the Fitbit is totally dead.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Feb 06, 2011
  • 6771 Answers
SOURCE: My powered USB port on my Dell Latitude D410 shorted out. Can this be repaired/replaced?
The USB plug will need to be removed from the computer, if luck is with you the computer will work, if no part is available, use a none powered USB hub on a spare port if available to run your applications.
Posted on Jun 23, 2012
yyyyyy85626
  • 7 Answers
SOURCE: Fitbit set the time ?
You say tttttttttttthhhhhhhhh mmmmmmmhhhhhhh this is really tasty and then it will automatically set to the right time
Posted on Dec 16, 2016
emissionwiz
  • 85206 Answers
SOURCE: how do you set clock on fitbit
You must sync the clock to a computer via USB
Posted on May 19, 2017
  • 32 Answers
SOURCE: the time on my fitbit is incorrect. How do I fix that?
  1. From Fitbit app dashboard, tap the Account icon.
  2. Tap Advanced Settings.
  3. Turn off theAutomatic time zone option.
  4. Tap Select time zone and select the correct time zone.
  5. Sync your tracker.
See you later and hope this helps!
Posted on Oct 30, 2017
I have my fitbit charging to my mac. How do i know that it's syncing?
Charging is just putting power into it. For Syncing you need the Fitbit Connect app for Mac
fitbit syncing to my mac Google Search
Aug 10, 2018 | Exercise & Fitness
Fitbit has wrong time. How do I change it?
-Log in to your fitbit.com dashboard and click the gear icon in the top right corner. -Scroll to the bottom of the Personal Info page and modify your timezone. -After saving your changes, force sync your tracker: Click the Fitbit Connect icon located near the date and time on your computer. Click Sync Now.Oct 13, 2016
SOLVED: Correct time cannot be set on my Fitbit - Fitbit zip - iFixit
https://www.ifixit.com/Answers/View/.../Correct+time+cannot+be+set+on+my+Fitbit
Fitbit has wrong time Google Search
Jul 30, 2018 | Exercise & Fitness
Manual for Alta Fitbit How do I set the time and date for my fitbit
You set the date and time from the Fitbit App or Fitbit Connect when you setup or sync the fitness band with the computer/tablet. Open the Fitbit Dashboard and then tap (or click) the Account icon. Enter the Advanced Settings menu and check the Time Zone section. If needed, turn off the Automatic option and manually set the current time zone. The Alta will display the date and time based on the time on your computer/tablet when you synced the devices. See https://help.fitbit.com/articles/en_US/Help_article/1176/?q=set+date+amd+time&l=en_US&fs=Search&pn=2 . This is the "How do I change the time on my Fitbit device" FAQ.
Alta has the manual for the Fitbit on the product support page: https://help.fitbit.com/?p=alta . The direct link to the manual is https://staticcs.fitbit.com/content/assets/help/manuals/manual_alta_en_US.pdf . Additional device help is available at the help page: https://help.fitbit.com/ .
I hope this helps.
May 02, 2018 | Exercise & Fitness
You have the wrong email address for my Fitbit how do I change it
FIXYA unpaid volunteer service is not connected to Fitbit.
Unpaid volunteers answer questions through the internet.
Fitbit has a website, and you should contact them to change the email address.
You can use http://www.google.com to search for other Fitbit web sites.
https://www.fitbit.com/login?redirect=https%3A%2F%2Fwww.fitbit.com%2Fuser%2Fprofile%2Fedit
Apr 11, 2018 | The Computers & Internet
I let my fitbit battery die and now the clock is wrong and I do not know how to set it. can you show me how to set it?
Charge the fitbit and then connect it to your PC or Mac. When the fitbit has completed syncing, the time will be correct based on the computer time.
Apr 06, 2018 | Exercise & Fitness
I got a new Fitbit and while setting it up it keeps telling me the email address is already an existing account
Solved: Email address rejected at setup - Fitbit Community
https://community.fitbit.com/t5/iOS-App/Email-address-rejected-at-setup/td.../837676
Nov 21, 2015 - 13 posts
Solved: I tried to set up my fit bit flex but was using either the wrong app or trying with the wrong fitbit device. ... Now, using the correct app, for the flex, it won't accept my email address because the app says that it's already in use. .... When you install and log on to the Fitbit App, select "Existing User" instead of "New User". Entered wrong email address during set up
9 Jun 2017
Email already in use
4 Aug 2016
How to change incorrect email address
24 Dec 2015
BRAND NEW SURGE BUT CANT SETUP SAYING ..EMAIL ...
28 Aug 2015
More results from community.fitbit.com
Fitbit and while setting it up it keeps telling me the email address is...
Mar 30, 2018 | The Computers & Internet
How do I change the time on my fitbit blaze
Why is the time wrong on my tracker
Jun 07, 2017 | Exercise & Fitness
How do you set time on fitbit surge?
I downloaded the Fitbit app on my iPhone , followed the steps to pair with the surge, and voila, the correct time is picked up from the iPhone automatically.
Mar 06, 2015 | Fitbit Surge Large-Size Fitness Watch with...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
