SOURCE: Microwave not working
It sounds like the magnetron is overheating and tripping its thermostat / thermal cutoff. The magnetron will likely need to be replaced along with the the thermostat.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
To get parts, see https://www.mcappliance.com/partorder.aspx
But they don't list the magnetron itself at their Web site, so you may have to look at the sticker on the mag and find a generic (like 2M234M1 for example) by searching by that part number at http://tinyurl.com/gv383
SOURCE: power windows and blower motor
check for inline fuses. wire that will melt if theres to many amps running through it usually under the hood. hope this helps
SOURCE: refridge stopped working after a power surge
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
SOURCE: Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
