SOURCE: proper batterie hook up on minn kota 70 thursh
Raventrans click this link to take you to a website which will you can click on schematics. I suggest adding a 50 amp fuse for your 70 lb thrust unit. scroll to the end of the schematic to find the battery hookup for a 24 volt hookup.
http://www.mikesreelrepair.com/./index.php
SOURCE: I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
SOURCE: i have a minn kota deckhand 35 that wont wind up.
Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
Good Luck!
SOURCE: Trolling motor doens't work
I have a trolling motor and can't seem to get it to come on. I seen it work when I got the boat. But now it won't come on.
