What causes an E01 error code on the CT Electric Cooktop control panel?
CT E01
STEPS TO VERIFY ISSUE:
Turn the home circuit breaker to the unit off for 30 seconds then back on again. Then retest the unit operation.Or contact the maker direct. They are expensive units and in my experience, if you get 2 years out of them in a commercial setting, you are lucky!
Usually E0 39 or E 39 or 3 039 is mismatch between your new board and current boards. Do a reconfig: install new board. Plug in. If you get the 39 code push one of the burner on/off buttons to make the beeping stop and blank display. Then, push and hold right front and right rear UP buttons simultaneously until 88 appears in display. Then press and hold left rear and left front UP buttons until beep sounds and configuration starts. A few seconds later it should clear and be all set! Hope this helps.
It appears the main control has detected a faulty or error condition. "E0" should be followed by two more digits to indicate which error has occurred. Let's try turning electrical power supply off. It is necessary to wait roughly ten minutes to reset cook-top main controls. If resetting the power does not correct the issue or provides a new error code, at this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
e 3 is error because of high voltage may be more than 30 kW at your house......it will not work with it u have to buy a voltage regulator for it........
Thanks for using FixYa. Error F2-E0 in your Whirlpool range indicates shorted keypad. To resolve this issue you’ll have to replace the electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
hi my name is mark, you need to check local electrical code before wiring cooktop. if it is allowed the white and ground/copper can be tied together with green from house. but if not allowed you will have to run a seperate white wire or new 8ga 3 wire/ with ground from breaker box. check the code first. and shut off power before you wire cooktop. thanks for your question.
