Washing Machines Logo
Jeff Lee Posted on Aug 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 80 series will not drain. And go to spin cycle.
Tom Chichester
Level 3:
Top Expert:
  • Kenmore Master 62,329 Answers
  • Posted on Nov 11, 2020
Tom Chichester
Kenmore Master
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
672063
Points
975369
This could be failure of the cycle timer or some element connected to it such as the pump.
5 Related Answers
Anonymous
  • 5911 Answers
  • Posted on Apr 14, 2008
SOURCE: Washing machine will not drain/go into spin cycle
Check your lid switch. If the lid switch is not making proper contact, or is broken, the washer will fill, agitate (some model washers won't), then just stop when it gets to the spin cycle. If this is what you are experiencing, then this could be a quick and easy repair for you.
Try opening an closing the lid. If you don't hear a clicking noise when the lid closes, the lid switch may be bad or loose. It is mounted under the opening of the tub rim on the right-hand side and held in place with two screws. Make sure the lid strike ( a small plastic piece) is present on the lid as well. This closes the switch contacts when the lid closes. If the lid switch does not function, the washer will not complete a wash cycle.
If the determine the switch and/or lid strike is broken, searspartsdirect.com carries the parts need. Just type in the model number you provided and you will find the lid switch under the "Top and Cabinet" heading as item #11 (part #3949238). The Lid Strike is under the same heading as item #20 (part #350733).
If you need advice on how to replace the lid switch please post back and let me know.
If I'm off the mark here, please post back with comments and give me a little more elaboration on what your washer is doing or not doing.
PS You do not need to drain the tub to replace the switch. If you wish to drain it, however, and want to by-pass the lid switch, I can give you instructions on how to do this as well.
Anonymous
  • 1028 Answers
  • Posted on May 01, 2008
SOURCE: kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Anonymous
  • 261 Answers
  • Posted on Sep 15, 2008
SOURCE: KENMORE SERIES 80 WASHER
There is three things on this machine that concern me. Last week I rebuilt a series 80 and it did the same thing, mostly on perm press. It turned out the timer was fine and the mechanical had not been rebuilt in years. Because of this the motor could not spin fast enough to fling the water plus the pump was leaking. I need three things from you. Is leaking water and oil when looking under the machine, does the motor hum loud even when functioning normally and when its spinning lift the lid, is it still rotating after a quick count to 7? Drop me a line I would like to help.
Sears Tech Too
Anonymous
  • Posted on Dec 09, 2008
SOURCE: Kenmore 80 series won't spin
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
Anonymous
  • Posted on Jan 05, 2009
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
3answers
Kenmore 80 series will spin when draining, but not agitate or spin during spin cycle.
Hello. I'm a little confused at the description of the problem. You indicated it, "will not agitate during wash cycle or spin during the spin cycle." But later in your description you indicated, "It will however, drain and spin after wash cycle and during the rinse cycle." I'm not sure if you description was an error but it sounds like you will need to replace the coupling which is part number 285753A.
1helpful
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Kenmore series 80 washer won't drain after wash cycle
Try the 'drain' portion of a few of the other cycles (heavy, perm. press, delicates) and see if it will drain/spin there. You can also try advancing the timer slowly through the 'spin' portion to see if it kicks in anywhere.
If it will rinse and spin in the other cycles, you most likely have a bad timer.
Hope this helps.
Kenmore Series 80: Machine does not drain or spin at the spin cycle.
Make sure there is voltage present to the motor when the cycle is ON>
If not the program controller is faulty, If yes the motor must be checked for errors.
Since both the drain and spin is not working the fault seems to be from the program controller as there is no output to the drain and motor.
So check the controller for the lack of output, try choosing a different program cycle to confirm..
I have a Kenmore 80 series top load washer. It will not drain during spin cycle. If I run it through a second spin cycle it will usually drain. Any ideas
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
2helpful
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
No spin cycle
Something simple. Plug off the wall mains. Find your pump, dismantle to locate block. Before that you could check out your filter to clean out.
2helpful
Kenmore Series 80 Washer Won't Spin
Your timer has failed to initiate a pause for the transmission to lock in.
Replace your timer. Solve your problem.
Alexander
vince
