A blinking orange light on appliances such as refrigerators and freezers indicates that the "supercool" or "superfreeze" feature is active. These features are designed to quickly cool or freeze the contents inside the device. A flashing light serves as a visual cue that the unit is actively working to quickly cool or freeze food. Once the desired temperature is reached, the light will stop flashing, indicating the unit has completed the cooling or freezing process.
When the panel lights on your Defy fridge freezer are flashing, it usually indicates an error or a specific condition that needs attention. Here are a few steps you can try to troubleshoot the issue:
Power Reset: Start by performing a power reset to see if it resolves the flashing lights issue. Turn off the fridge freezer at the main power supply or unplug it from the electrical outlet. Leave it unplugged for a few minutes, and then plug it back in or switch on the main power supply. Check if the lights continue to flash.
Check Error Codes: Consult the user manual or documentation for your Defy fridge freezer to identify the meaning of the flashing lights or any error codes displayed on the panel. The manual will provide specific information on what each flashing light or error code signifies and any recommended actions to resolve the issue.
Temperature Settings: Ensure that the temperature settings on the fridge and freezer compartments are set correctly. Incorrect temperature settings can sometimes trigger error codes or unusual behavior. Adjust the settings to the recommended levels and observe if the flashing lights persist.
Contact Customer Support: If the flashing lights persist or you are unable to identify the issue using the manual, it's recommended to contact the Defy customer support or an authorized service center. They can provide further guidance and assistance in diagnosing and resolving the problem.
Something to think about from the manual for your freezer. Also I would check the temperature of your freezer with a thermometer to make sure it is freezing ok .Troubleshooting
If the appliance does not work, before calling for Assistance (see
Assistance), check for a solution from the following list.
The green POWER indicator light does not illuminate.
• The plug has not been inserted into the electrical socket, or not
far enough to make contact, or there is no power in the house.
The motor does not start.
• The appliance comes with a motor protection control (
see Start-
up and use
The indicator lights are on but the light is dim.
• Pull out and reverse the plug before putting it back in the socket.
a) The alarm sounds.
a) The refrigerator door has remained open for more than two
minutes (the buzzer will stop sounding when you shut the door) or
the correct switching-off procedure was not followed (
see
Maintenance
b) The alarm sounds and the two yellow indicator lights
flash.
b) The temperature in the freezer is too high. Check the quality of
the food products and dispose if necessary.
+ buzzer =
Heating is excessive
c) The alarm sounds and the two yellow indicator lights
as well as the green one flash.
c) The temperature in the freezer has reached a dangerous level.
The food must be disposed immediately.
+ buzzer =
Heating danger
b/c)
In both these cases the freezer will maintain a temperature of
about 0°C so that the food does not re-freeze.
To turn off the acoustic signal open and close the refrigerator door.
To restore normal operation bring the FREEZER OPERATION knob
setting to
(off) and turn the appliance on again.
The green POWER indicator light flashes.
• The appliance is not operating correctly. Contact the Technical
Assistance Centre.
The refrigerator and the freezer do not cool well.
• The doors do not close properly or the seals are damaged.
• The doors are opened too frequently.
• The OPERATION knobs are not on the correct setting (
see
Description
• The refrigerator or the freezer have been over-filled.
The food inside the refrigerator is beginning to freeze.
• The REFRIGERATOR OPERATION knob is not on the correct
setting (
see Description
• The food is in contact with the back inside wall of the refrigerator.
The motor runs continuously.
• The SUPER FREEZE button has been pressed (rapid freezing):
the yellow SUPER FREEZE light is on or flashing (
see
Description
• The door is not closed properly or is continuously opened.
• The outside ambient temperature is very high.
I now have these kinds of refrigerators and freezers to maintain, and have found some will take as much as 18 - 24 hours before the lights will shut off after they have overheated from their doors being left open.
God bless your day.
Blow through the jet and heater gauze to make sure the flame is reaching the end of the thermocouple. If the flame is going out all the time suspect the thermocouple is at fault
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sounds like the unit may be stuck in to defrost . The defrost clock is usually inside of the refrigerator compartment up by the thermostat controls. you can take a screw driver and advance the controller to make the compressor come back on . usually when they start to stick they neeed replacing. good luck and please don't forget to rate the answer please. Thanks for using FixYa.
