Question about Video Game Consoles & Games
Epson moviemate 72. Inserting disc was sort of difficult and it did not automatically pull disc in. now I can not remove disc with eject button which does not even seem to be trying..
    Top Expert:
  • 52,971 Answers
Drive failure
Posted on Aug 15, 2019
SOURCE:
  • 97 Answers
SOURCE: Cannot play or eject disc
Loading gear jam or broken loading motor belt. Disasemble unit to remove disc and check operation of motor and gear assembly. Repost the results so we can better help.
Posted on Jun 11, 2007
Drawsalot
  • 38 Answers
SOURCE: DVD PLAYER/BURNER
Harry, two possibilities that are immediately apparent. One, the lens on the drive is dirty. Stop by a department store and buy a CD/DVD laser lens cleaner CD and put it in the drive several times, making sure that it tries to read it each time. This can brush away the debris on the lens and it may work again. Two, the drive motor or lens assembly (that moves) has failed. My experience is that these drives have a 2-3 year life span. Luckily, they are now bargain-priced and you can pick them up at your local discount store and replace them yourself.
Posted on Nov 12, 2007
  • 3 Answers
SOURCE: Disc removal
This is what LG customer service will instruct you to do. I have a LG LDA-511:
1. Unplug your unit.
2. After unplugging, wait a few seconds then press and hold the power button (yes, while the unit is unplugged). This resets the unit.
3. Plug in your unit.
4. Press the eject button.
If the disc does not come out, then you need service from an authorized service representative.
Posted on Aug 11, 2008
  • 6 Answers
SOURCE: xdvd8181 not accepting any discs
Check this.
http://www.fixya.com/support/t892341-cd_wont_stay_in
Posted on Aug 30, 2008
SOURCE: Disc Eject won't work after improperly inserting disc and since removing it.
I have an DZ-MV780 with the same problem. I found that the cover plate around the flash hot shoe only has a single screw. If you remove it and pull up the cover you gain access to the gear and lock mechanism. Hit eject and if necessary press on the white gears you see in front of the zoom switch. It should then cause the door mechanism to unlock and open.
Posted on Jan 25, 2009
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
My epson movie mate 55 dvd projector keeps telling me no disc when i put dvds in ?
Get a cd/dvd cleaning disc at best buys or Wally world.
The disc has tiny brushes, and sequences with the lazer pick up
to clean it of dust. This should be done every 10-15 hours of use.
Most folks never clean their CD or DVD player... do not know to.
99 times out of 100, this will solve the issue.
Nov 07, 2014 | Epson MOVIEMATE 60 PROJECTOR Projector...
Disc Stuck In 60G Console
  • Press the "Eject" button on the PlayStation 3 console and hold it for at least 10 seconds; if your PS3 has the "force eject" feature included it will eject the disc regardless of whether the console is frozen or not. Turn off the console and turn it back on before inserting new discs.
  • Unplug the power cord and any other cords from the PS3 console if the "force eject" feature does not work and you own a PS3 Slim. Turn the console upside down so that you have access to the bottom of the console.
  • Locate the small compartment door on the bottom of the console. Remove the door by pulling it up and off the console; a blue screw and a small hole should be visible inside the compartment.
  • Insert a Phillips-head screwdriver into the hole. Turn the screwdriver in a counterclockwise direction to manually eject the disc. Once the disc is removed, replace the compartment door and turn the PS3 console back to its correct position before reconnecting the power cable and any other cables you previously removed.
  • Jan 29, 2012 | Sony Playstation 3 (PS3) Console
    Game disc dosent pop up and when click on stuff it freezes
  • 1
  • 2
  • 3
  • 4
    CAN AN EPSON MOVIEMATE 72 BULB BE USED ON A EPSON 50 or 55
    Hi I am Vortash .. I have just downloaded both manuals for these projectors from http://www.safemanuals.com and they look by all intensive purposes the same the part number is however one digit different ...on the 50 it is ELPL44/V13H010L44..on the 75 it is .
    V13H010L43 .. so as you can see almost the same but different .. look in the manual and check the luminance and the specs if they are the same I should think the only difference is the carriage .. but it will be down to you to try it other than that give Epson a ring ask for support and I am sure they will help you ... Regards Vortash
    May 18, 2009 | Audio Players & Recorders
    Aug 24, 2006 | Hitachi DZ-MV580A DVD Camcorder
    Video Game Consoles & Games Logo
    12 people viewed this question
    Top Video Game Consoles & Games Experts
    Ekse
    Marvin
    Marvin
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
