Question about Chips Computers & Internet
How to erase memory chips
I want to erase the memory chip from a tablet that is not working..... Won't let me download anything on my new tablet because it's on the old one
    Top Expert:
  • Chips Master
  • 28,490 Answers
Rebooting erases everything in RAM Memory. EPROMMS can't be reprogrammed by you.
Posted on Aug 14, 2019
SOURCE:
Cpyles07
  • 56 Answers
SOURCE: Adding memory.
its either incompatible damaged or over its limit
Posted on Dec 06, 2007
robmcd27
  • 423 Answers
SOURCE: memory card not working? ( fuji finepix Z20fd Digital Camera)
Hi there.
When you start using a memory card, you must format the card in the camera first...using the camera menu. If you don't the camera won't read the card properly. Try that and I bet it will work for you.
Rob
Posted on Mar 09, 2009
  • 3 Answers
SOURCE: How do I clear the SD memory chip so that I can reuse it?
you can probably clear it manually on the camera by going to the menu and looking for a delete or clear option.
Posted on May 27, 2009
leepania
  • 1099 Answers
SOURCE: We insert a memory chip into our Kodak EasyShare
Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
Posted on Jan 04, 2010
LongPockets
  • 1177 Answers
SOURCE: I have a Bushnell trailscout
Probably the first thing to try is formatting the card. There should be a function in the setup menus to do this. If it won't format or gives an error when you try the card may be incompatible. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. Some cameras have a capacity limit, and won't work with cards that are too large (in memory terms).
Posted on Oct 30, 2010
My camera is saying its full what do i do it wont let me take any pics what so ever
I had the same problem with my cannon. my guess is that your memory chip could be full or not working. remove your memory chip, stick it in your computer memory slot and download and erase. that should work. if not go out and buy a bigger memory chip. hope this helps
Feb 09, 2015 | Vivitar DVR 380 Digital Video Recorder
I have new tablet and camera doesn't work
The storage card (aka memory chip) is not necessary to use the camera. If the camera is not working on the tablet, then there is something wrong with the tablet itself. Return it and get a different unit from the store at which you bought it.
Oct 02, 2014 | Computers & Internet
I'm a laptop engr i have a problem with tx 2500 tablet, it will power but no display each time i open it to heat the grahics chip it will diplay and work for 2 or 3 days after it won't display...
This sounds like a serious internal malfunction ,,im sorry i dont know your model exactly,,i dont think you actually need to " heat the chip" they do function at no to low temperatures.you describe really a ram memory malfunction which may need just changeing ,sounds like a curious problem.
good luck anyhow
Davey Snake!!
Jul 22, 2011 | HP Pavilion tx2500z Tablet
When putting in new memory chip (up grade) in the inspiron 2200...will it erase all the programs already on the computer?
No it will not erase programs, a memory chip is used when power is on your hard disk holds permanent data.
May 15, 2010 | Dell Inspiron 2200 Notebook
Photos are accessible on the camera but not on the chip to download. how can i get them onto the little chip?And how did this happen? I've taken 100's of photo's and just pulled out the chip, plugged it...
If , when you pull out the memory card, you don't use the "safely remove hardware" function, you run the risk of corrupting the card. If you use the computer to erase the card, you run the risk of corrupting the card and causing it to not work properly in the camera. If your pics are safely downloaded into your computer, try formatting the card in the camera to get it to work again.
Mar 07, 2010 | Nikon COOLPIX P90 Digital Camera
Will replacing the car battery clear the computer chip?
No, it will not clear the computer. You can safely replace you battery and not worry about the computer chip being cleared. This will no more erase the memory from the computer in your car than unplugging a computer will erase the hard drive on a PC. The ECU memory is programmed in and will not be erased. It may erase the radio code & presets and require you to insert it again but that is all.
Jan 14, 2010 | Saturn SC2 Cars & Trucks
After original 1st downloads cant deleat or download any thing/fi
the memory chip on the internal circuit is got stuck  on stand by mode .so its not supporting any functions.needs a particular software to wipe the old memory from the chip to insert new data on it.just take it to the local repair center as to make it proper.
Jan 27, 2009 | Coby MP705R Digital Media Player
Long beep error on startup
try cleaning up the copper terminal of your memory card with a pencil eraser, do it carefully by avoiding contacts with the chips or I.C. carefully swipe the eraser on the copper terminal only and if your sure that it is already clean, carefully wipe the teminal with a soft cloth again avoiding contact with the chips. if the problem occurs again, buy a new memory card.
Sep 22, 2008 | Computers & Internet
BOOT falilure after RAM installation
Did you make sure that the new RAM was compatible with the motherboard? ...?
Some RAM manufacturers are not compatible with certain motherboard manufacturers....
Aug 20, 2008 | PC Chips M810DLU (M810DLUV75C) Motherboard
No rubbery material on memory chips
To be honest, you shouldnt have opened your xbox 360 in the first place because now you voided your warranty. Also, i dont think it means anything.
Mar 30, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
18 people viewed this question
Top Chips Computers & Internet Experts
Marvin
Marvin
Alun Cox
tomcattech17
tomcattech17
Are you a Chips Computer and Internet Expert? Answer questions, earn points and help others
