SOURCE: cannot edit stored phone numbers
goto phone book hit menu find the number and or persons name you want to edit edit the number hit ok to get to the number or you can do the easier way
delete there name and number and put it back in with the right digits
SOURCE: Help with Woods 59018/59028 7 day digital timer
The usual connection for this type timer is the house black power to the timer black, the house white power to the timer white and the , the light black wire to the red timer wire.
If you only have two wires, one black and one white, at the switch location, then you cannot use this style timer , as it needs a neutral. You should return this timer and get one that does not require a neutral connection.
Please Vote !!
SOURCE: how do I turn off
No offense intended but you need to step away and read the instruction manual step-by-step. One point I can make: The three hours you're seeing in the display when you first plug the unit in are simply telling you how long the default white bread mode is going to take to complete. It's merely a counter that counts down so at any time you glance over at the machine you'll know how much longer it's going to be before the bread is finished. The digital display has NOTHING to do with the delay timer until you start pressing delay timer arrows.
Hope this helps!
Hi Rich Gerbounka, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
sorry .outdoor Portfolio transformer. Of courser made in China 300w 120 volt. Has digital controls for dawn to dusk plus 1 thru 9 for hours once activated but that is my problem. Doesn't respond to shutoff hours. Immediately goes on no matter what hours I set yet does shut off pressing zero. I believe time to throw out unless doing something wrong
