CONNECT WIFI NREPEATER TO MY LAPTOP - Computers & Internet
  • 29 Answers
You should be able to connect to a repeater the same way that you would connect to a wi-fi router.
Need more info to really answer this. Were you connected before. Is the repeater configured. What brands???
Posted on Aug 14, 2019
SOURCE:
I cannot connect my Dell XPS M140 laptop to WiFi since we got a new router.
Fn/F2 probably turns the wifi on/off but your problem is you need to connect to the new device, and enter the new password. In the tray (notification) area, click the Network or wifi icon, find the new device (You may have to click Connect first.), connect to it and enter the password when prompted.
Apr 14, 2018 | Dell Computers & Internet
How do my turn on my wifi on this laptop?
Hi Ken, The link below is a youtube video showing how to connect your laptop to the WiFi, Also There's videos down the right side of the link that may help as well...........CHEERS..
How to connect your Laptop to Wifi
Apr 30, 2016 | Gateway M675 Notebook
My laptop wont connect to my wifi just started a few weeks agto
Acer Wireless Not Working? - Easy Fix by Drivers.com
www.drivers.com/update/drivers-news/acer-wireless-not-working/
Jun 17, 2014 - In some Acer models you can use a combination of keys on the keyboard to ..... My acer aspire wont connect with wifi, it say windows cant connect.... I've just had a similar problem with my Acer Aspire laptop (wireless .... It is startedto happen just a month ago before it was ok I am using this since 6 months.
Acer notebook won't access the internet [Solved] - CCM
ccm.net > Forum > Network
Sep 17, 2014 - My Acer Aspire one series notebook says it's connected to my wireless... I know for a fact that my wireless is working fine, as my normal laptop is accessing it and ... it a while ago, sometime in Autumn 2010) but now it just won't work. ... 1) First make sure that you have configured the WiFi settings correctly. Can't get Aspire One D255 to connect to wifi [Solved] - CCM
Jan 15, 2015
Can't Access Internet-Wireless Working! [Solved] - CCM.net
Dec 19, 2012
My laptop Browsers won't connect to the web [Solved] - CCM
Oct 10, 2012
More results from ccm.net
wifi wont connect all of a sudden - Aspire - Laptop Tech ...
Dec 14, 2015 | Acer Computers & Internet
How do I add wifi to my dell inspiron 1000 laptop using a hotspot?
  • same way you connect to any wifi. switch on the hot spot option in the device u r using as a hot spot then go to your laptop and turn on the wifi.....if u r lucky the laptop will automatically search and give you an option to connect to the wifi hotspot....otherwise u will have to go to wifi settings of your laptop and manually search for the same....visit dell.com for further help.
May 28, 2014 | Dell Inspiron 1525 Notebook
MY LAPTOP DOES NOT CATCH ANY WIFI SIGNALS
methinks that you need to check these two items first
a. look for a physical switch along the sides of laptop(could be sure if the model number were here) and turn it on
b. open start/control panel and look for wireless icon click on that and ensure it's active
if that does not work then make sure you have one installed
start/control panel/system icon
opens panel go to device manager(should be upper left first option on list)
look for network adapters
see if wireless is listed
if it has a yellow ? mark then you need to right click to uninstall
go to top of that panel and scan for hardware changes
may need to restart computer after this segment is complete
May 25, 2012 | Computers & Internet
How do I connect my netgear router to my desktop internet to use with my laptop. Followed instructions but when cable is disconnect from my laptop I can't connect to the internet
First Connect the Desktop with Netgear Router with the Ethernet cable. Open the Netgear GUI and configure a Wireless Network. Once its configured, switch On the WiFi switch from your Laptop and try to connect your Laptop. Make sure your laptop has an in-built Wifi adapter, if it doesn't then you would need to buy an USB based Wifi Adapter.
Also if you want to use the Internet with your Desktop PC without being connected with the Netgear Router then make sure it has Wireless connection capability.
May 10, 2010 | Computers & Internet
Not able to connect wifi in my lapopo
In connecting through a wifi, there are two factors to consider. (1) Wireless Router broadcast and (2) Wireless Receiver.
Make sure that your network router is broadcasting wireless internet or wifi. Also, you have to know if you need a pass key or password in order to connect to the wireless network.
Now, given that there is a wifi spot, your laptop should automatically recognize the wifi broadcast and negotiate connection without your intervention. This will only happen IF AND ONLY IF your laptop has a wifi radio receiver and that it is TURNED ON. When it is turned ON, it will connect you immediately if the network has no pass key set. If there is, then you have to enter that key when you try to manually connect it. (Right click on wireless network icon on system tray. Then it should say: Wireless Network Available. Then Click CONNECT)
To turn your wifi radio receiver ON, slide a switch button to ON position depending on your laptop model. If you dont have that kind of switch, look for the wifi icon printed in the keyboard keys. In some laptop, it is in F2. Now Press FN+F2 to turn wifi radio receiever ON and OFF.
Feb 04, 2010 | Toshiba Satellite A100-S8111TD Notebook
Cannot seem to get wireless connection . ethernet connection works fine . do i need usb adapter to bring my 3 year old laptop up to N standard ? Ray
If your laptop does not have a wireless card built into the computer then yes I would go and buy a usb wifi adapter because you cant get wifi if you dont get one.
Sep 29, 2009 | NetGear DGN2000-100NAS Router
Archos 5 wifi connecting problems
"hi have an archos 5, when trying to connect to wifi, keep getting "wifi error .(0)" or "wifi error .(21), i know i am in a wifi network area as my laptop and palm pda can connect ok, however the archos seems to keep scanning for networks until it eventually switches off, any suggestions would be greatly appreciated"
i have the same problem...PLEASE is there ANYONE who knows how to solve this issue.. my email is hbhuralal@gmail.com i need desperate help..
thankyou
Jan 06, 2009 | Computers & Internet
Open Questions:
Computers & Internet Logo
14 people viewed this question
Ekse
Alun Cox
