Whats the ohm values for a reheat valve for a aaon model RQ0033HE609000.
2 Suggested Answers
SOURCE:
Grubhead
  • 5686 Answers
SOURCE: I have a FISHER Model RS-914A and I don't know
Are they burnt up so you can't read the colour codes?
220 ohm even marked up as that could give a reading of 222 or higher (or lower) and work fine. Remember the gold or silver band gives a 5 to 10% varation in value.
Posted on Jun 01, 2010
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
Dec 28, 2015 | Sharp Televison & Video
Correct ohm value on a water tank heater coil part # wr13x10500
First neither the model number or the supposed part number are correct. Second is this the top or mid-line heater loop?
Usually it's not the coil that fails but the thermostat.
Jun 12, 2014 | General Electric WR13X10500 - WATER TANK...
What is the ohm and taper value of the input pot on the Tascam PA-150 Dual Power Amp?
Hi doc2714,
The Ohm and Taper Value is " 4 ohms or 115W per channel at 8 ohms "
for more details here is a link providing you with full specifications to your Amp.
http://www.broadcaststore.com/pdf/model/19184/tascam_pa-150.pdf
I hope this helps.
Mar 27, 2011 | Tascam Audio Players & Recorders
Hello, I need some help to fix my Gas dryer. When I turned on the dryer, I noticed the sound of rolling in the box. But the dryer is not heated up at all. Manufactuer / Model : Kenmore Gas Dryer...
gas dryer is on the right, it sounds as though the thermal fuse is bad, you can tape the wires together to test to see if it heats. As far as the rolling sound I would say it is the drum rollers:
http://www.applianceaid.com/dryers.html
Good Luck Tim. if you need further assistance just ask.
Dec 25, 2010 | Dryers
I have a FISHER Model RS-914A and I don't know what's the value of R211 and R212 . I removed these resistors and they measured 222 ohms. But I don't know if the value is 220 ohm. please help me with this...
May 31, 2010 | Audio Players & Recorders
I have a Toshiba projection T.V, model number 43J7DM.It is dead
247 is .050 watt15K ohm
404 is 0,25Watt 1K ohm
420 is 0.5 watt 10K ohm
513 is 0.25watt 100 ohm
However if you dont understand them dont play around with them you may end up doing more damage than what you have now. If resistors blow then some other fault has caused excess power to fuse them and that takes knowledge of how to measure the current at each step. Some of these resistors are related to the power board. Getting circuit diagrams from toshiba is difficult Quite often there is a diagram inside the chassis of each model.
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Toshiba 55H70 55" Rear Projection...
Where is 2001 Ford Explorer overdrive solenoid located?
inside the transmission, mounted on the transmission shift control valve body. There are four solenoids located on this valve body, it is difficult to explain which one does what, you can measure each one with an OHM meter, the OHM valve is hard to specify, but there should be an OHM value, it should not be shorted or open, hope this helps, let me know
Nov 20, 2009 | 2001 Ford Explorer Sport
Im trying to test the coil on my 1997 fatboy I need to know what ohms my meter should read
Sorry did not have that value handy; however they usually run 3 ohms or less. I do recall that you will have several different types depending on the model, I would defer to the dealership for the correct value on your model.
Aug 26, 2009 | Harley Davidson FLSTF - FLSTFI Fat Boy...
Our Aaon unit on the roof is not working correctly, the loovers have been ajusted to recirculate but it still isn't keeping up like like it should. What should I do? I already cleaned the condencer to the...
Hey there, Aaons are fun lol. How many circuits does it have, how many are running. There are manual reset high pressure switches on the discharge line at each compressor. Thoses are the simple things to tell ya first. Also feel the suction lines at each compressor to see if they feel cool and all the same. let me know
Jun 25, 2009 | Heating & Cooling
Sony resistor values?
It is recommended to use the same value due to the function of the resistors and their values.
A lower value will let the current flow a bit faster and the higher value will slow it down according to their design.
Try installing the same value of 220 ohms.
Hope this helps.
May 05, 2008 | Audio Players & Recorders
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Ekse
