Question about LG Televison & Video
I have a LG 55LB6000 problem,when i turn on the screen flashes on and off endlessly
    New Friend:
  • 5 Answers
A circuit has been blown and needs to be replaced
Posted on Aug 15, 2019
SOURCE:
Sony Wega flashes endlessly and won't turn on.
IF ITS A DLP TV REPLACE COLOR WHEEL THIS MAY BE THE CAUSE OF THE BUZZ AND ENDLESS FLASHING....I ASSUME ITS A DLP COS OF THE MENTION OF BULB IF NOT CHECK TRI BULBS STK AMPLIFIERS IF ITS THAT TYPE
Oct 08, 2015 | Sony Televison & Video
My LG 42LN5400 LED TV turns off and on in an endless loop. There is some light on the screen when it comes on, but then goes black before turning off. What part needs to be replaced to fix this?
seems like the issue with the power circuit .. the LED must be fine that is why you see the back light when powering on ..
do not replace any parts manually, call in a technician, incorrect part can do more harm than good.
Jul 23, 2015 | LG 42" Ln5400 Series Led-Lcd Fu1080P...
LG 42LD560 LCD TV
mainboard failure
I suggest you change tha flash memory .
This would be the first thing to try
Jul 11, 2014 | LG Televison & Video
Virgin Mobile LG Optimus V (vm670) won't load past LG screen
Yes there is hope You will need to flash over your phone try youtube or contact me if you need more help i will help you for a small fee.
Apr 23, 2012 | LG Cell Phones
Lg voyager- endless power cycle- how can i pull info off?!?!?
I just had my phone loop into an endless power cycle this morning, and this is what I did to get my pics and ringtones off:
1. Pull out the battery.
2. Hook the phone up to the computer with a data cable. The phone screen should show "battery required", and should stay on.
3. Open up BitPim (other programs may work) and get the files you need.
Once I had my files saved from the phone, I went ahead and tried to get the phone to turn back on normally with it still plugged into the computer.
As soon as I put the battery back in, the phone screen switched to the charging screen while still off. I power cycled it this way a few times, then unplugged the cable, and powered it on, it rebooted twice and finally powered back on normally.
Hope this helps you out!
May 13, 2010 | LG VOYAGER VX10000 Cellular Phone
Lamp light flashing when projector turned on.
Ordinarily this is not a problem. usually this happens to virtually every projector at start up. Reason is the projector needs to warn up before it project/beam unto the screen. But if you are saying it continues to flash endlessly, that is another issue. At any rate that doesn't seem to be the case since you didn't say so.
Sep 04, 2009 | Canon LV 7525 Multimedia Projector
Black screen on LG Neon phone
is the phone turning off because my lg neon turns off at random times
May 31, 2009 | LG RUMOR Cellular Phone
LG Voyager won't reboot
Interesting, normally the screen only appears with water damage, which I am sure Verizons customer service has continued to tell you that is the cause without thinking the customer might not know for themselves, The only way to fix this is to got to a Verizon Wireless store and ask them to do what is called a software flash, now it may delete all your information on your device but at least it will work, if you need any more help with this let me know.
Jan 02, 2009 | LG VOYAGER VX10000 Cellular Phone
Touchscreen turned itself off and keeps flashing. HELP
To fix this problem you will have to go to your local phone dealer. They would usually fix it up for free!!!
Sep 13, 2008 | LG KU990 Viewty
Televison & Video Logo
Ekse
