Transcend (589307) Media Logo
Posted on Sep 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pendrive not formatted
My 8 gb pendrive shows obyte free n obyte used
Manish Kumar
Level 2:
Scholar:
  • Expert 95 Answers
  • Posted on Sep 13, 2009
Manish Kumar
Expert
Level 2:
Scholar:
Answers
95
Questions
0
Helped
32764
Points
336
If u still having the same problem, follow these steps:
1.Insert your pendrive. open mycomputer, note the respective drive showing pendrive.
2. Then go to run and type cmd ( or go to command prompt)
3.It will show like: C:\> or C:\Documents and Settings\UserName>
4.Type the drive name of pendrive as shown in e.g
if drive is h: then type as
c:\>h:
h:\>format h:
it will format and ask for media name, you can give the name of your pendrive.
your pen drive is formatted. Now it will show the free space as 8G.B
Erickayan0
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Oct 28, 2015
Erickayan0
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
2070
Points
9
Hello! Have you formatted this pen drive when you use this drive on your PC at the first? Honestly, from my understanding, it is always necessary to firstly format the new flash drive before transferring anything new there to avoid flash drive not formatted error or RAW file system error problems.
But, now, you also do not worry! In such case, as with the left pen drive information, you can firstly take chance with RAW file system pen drive data recovery software to rescue all possible original data back. And then, format this flash drive on the same PC and see whether it can work effectively there.
Go learn to make pen drive data backups well all the time.
min_mo
Level 1:
Problem Solver:
  • Contributor 7 Answers
min_mo
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
Helped
4955
Points
20
Take it back to the shop or person you bought it from :D
  • min_mo Sep 13, 2009
    take it back to the shop or person you bought it from :D
    take it back to the shop r check if there's anything on there and then delete it
My 8GB kingston pendrive is showing write protected and couldn't format or copy files on to it...
i have my 8 GB Kingston pendrive i have formated it. But afterwords when i am going to copy some data ie photos and film it shows write protected, so how can remove this write protected from the same.
I have a 8 gb sandisk pendrive i used it to create a bootable usb after whn i format the pendrive it shows as 2 gb only please resolve this issue.
yes you still have a hidden drive of 6 gb try downloading this free sofware at this link below to recover the partition and what ever is on it, hope this helps
http://www.easeus.com/
I had a pendrive of 8 GB my friend tried to make a bootable pendrive so he changed some settings by command prompt. My pendrive storage capacity dropped from 8 GB to 3.44 GB I need a good solution please...
It seems that after your friend made it a bootable pendrive, he/she did not format it.The space has been used up by the installation files in the flashdrive,and these files may be hidden.This is likely to be the case with some command-line utilities for making bootable flashdrives.
To recover your space, simply format your USB pendrive.To do so on Windows XP,insert the flashdrive into your PC, go to My Computer, right-click the USB pendrive,and in the window that appears, click the tools tab and select the Format option.
That should solve your problem.
2answers
My kingston 32gb pendrive not format , how to format my pendrive please give me step by step solution thanks & reghardes subhash
normaly your pendrive not formated so cmd (command prompt) use.
Run - cmd (type) than enter
format (pendrive colon) than enter
continue process which computer show
your pendrive is formated.
3helpful
2answers
40 GB Kingston Pendrive Showing 8 MB & unable to format it.
Format it using a format utility which you can download it from any free software sites, type in format utility.
Cannot format my pendrive
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
Problem with transcend jetflash -8 gb " files in unknown format"
2answers
Displaying write protected while loading and deleting files
Top Transcend Electronics - Others Experts
NOEL
NOEL
Larry
August Brown
August Brown
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
