Dryers Logo
Steve Lundstrom Posted on Aug 08, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Kenmore Ultra Wash 665.13749K603 the the keypad will not light up or respond. When I plug it in and close the door, it attempts a drain cycle for a few minutes and then shuts off. Unplugging will not reset the keypad. I’ve already replaced the thermal cut off fuse with no change. I used an Ohm meter to test the 14pin connector and it has current. Suggestions?
randymanfive
Level 3:
  • Master 501 Answers
  • Posted on Aug 12, 2019
randymanfive
Master
Level 3:
Answers
501
Questions
0
Helped
147980
Points
1170
I would agree with the control board being bad.
Rudy Lorenz
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 15 Answers
Rudy Lorenz
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
15
Questions
0
Helped
13177
Points
19
Contact the mfg help line to see if there is a way to test the control board. Ask for support or technical services.
5 Related Answers
A-OK
Glenn Bacon
  • 10 Answers
  • Posted on Nov 23, 2008
SOURCE: Kenmore Ultra Wash Diswasher - wont move past initial cycle
Motor trying to start. blockage in pump, or bad motor!
Anonymous
  • 530 Answers
  • Posted on Jan 06, 2009
SOURCE: Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
Anonymous
  • 1214 Answers
  • Posted on Jan 24, 2009
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Anonymous
  • 131 Answers
  • Posted on Feb 22, 2009
SOURCE: West Bend 33600 doesn't heat - how do I test thermal fuse?
Yes, if you have no continuity across a thermal cut-off, that means it is blown.
Anonymous
  • 51 Answers
  • Posted on Sep 27, 2009
SOURCE: Kenmore Ultra Wash Dishwasher - no lights, won't reset
check wire nuts that were used to install power cord/it is on the right hand side of toe kick if ok there is a fuse on the control that you can replace located top of door
The smart wash light on my kenmore elite model 66513753K602 is flashing. I have tried the suggested button sequences to reset it and they have not worked. How do I troubleshoot it to determine which...
From the tech sheet:
CHECKING KEYPAD
OPERATION
A rapidly blinking LED over
one of the keys of the keypad
(or sometimes a "dead"
keypad/console) indicates one
or more key switch lines are
stuck or shorted on either the
control or the keypad. To
determine if the control or
keypad is faulty, do the
following test:
1. Unplug dishwasher or disconnect
power.
2. Open the dishwasher door.
3. Open console and disconnect the
keypad ribbon connection from
the control (at P1). Make sure all
other connections are made.
4. Put console back together. Do not
close the dishwasher door.
5. Plug in dishwasher or reconnect
power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
? If the control is OK (no longer
sees shorts with the keypad
unplugged), it will respond by
turning on a Drain Motor for
2 minutes. Check and/or
replace the keypad if the
control responds OK.
? If the control is not OK (still
unplugged), then the drain
motor will NOT respond and
will remain off. If no response,
replace the control.
Lights on console are off and unit won't start.
Hello Brian,
I had a similar problem with my dishwasher sometime ago. My husband tried to fix it following the owner's manual instructions but nothing happened. Tired of trying it I called a technician and they came the same day and fix it! They had to replace the keypad, I don't remember how much it was but I know that it was a fair price, around $150, much less than buying a new one!
I'll give you their contact info just in case it helps you. Good luck!
Appliance Repair Toronto Fix Appliance Repair
Kenmore ultra wash D/W wont start. can cancel things but wont start no heat light and lock on light alternates.
Well, I could be wrong, but is sounds like a bad control module or control console (keypad).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Why are all lights staying on kenmore ultra wash dishwasher 665
I'm not sure if all of your lights are staying on, but if it is several at least and your cycle is done....just push your door closed again and the lights should go out. I find that after my cycle finishes, if I don't completely close the door, most of the lights stay lit. I have to be sure the door snaps in all the way when I close it or the lights stay on.
Jul 19, 2014 • Kenmore 665
Why won't my kenmore ultra wash dishwasher drain?
It could be an obstruction in the drain hose (most common), or in the air-break (if you have one), or at the check valve, or something may be blocking or stopping the drain pump impeller. Try this: Close the door and press Cancel. (Or if your dishwasher has the controls that are hidden under your counter ledge when you close the door, then press Cancel first and then close the door. Do you hear anything? Is the drain pump trying to run? If so, then start at your garbage disposal and work backwards. If you got a new garbage disposal installed, make sure that you (or the installer) remembered to knock out the hard-plastic plug at the end of the dishwasher connector port. Also make sure you don't have a clog right there. If that's okay, then check the drain hose (or air-break, if you have one) for clogs. If that's okay, then you will probably want to call a professional because the next steps involve removing and dismantling the drain pump.
1helpful
2answers
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
2helpful
Wont do anything, not even drain
Try unplugging the unit for 15 minutes then plug it back in. If that fails it sounds like the inline fuse which means you will have to pull out the dishwasher and look near the pump is blown and fuse needs to be replaed
1helpful
2answers
18helpful
2answers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
