SOURCE: 26 Cu Ft Side By Side Maytag Refrigerator: Relay Failures
you have more than likely got a bad compressor it is pulling to many amps you need to replace the compressor
SOURCE: Kenmore 26 cu ft side by side refrigerator 51673100
I think the Adaptive Defrost Control may be your problem part number 12566102 You may find it inside the fresh food compartment and behind the controls where you adjust the tempertaures. I will return with photos and links, Sea Breeze
Testimonial: "Great Help Thanks!"
SOURCE: my kenmore 19.7 cu.ft. chest freezer is not
Place a volt meter set for amp draw around one wire of the compressor. If you do not have a constant amp draw replace the start relay on the compressor.
If you do have a constant amp draw the compressor is bad or you have a refrigerant leak.
Testimonial: "Thanks 4 the help. told me what i needeto know"
SOURCE: I have a Frigidaire (Electrolux)
Being only 3 years old, it should be repairable. Call around to some loca appliance repair shops to see if they can help you.
Good luck, and hope this helps.
SOURCE: 1.7 cu ft refrigerator -
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
