Question about Tablets & eReaders
My tablet will not charge, what can I do - Tablets & eReaders
    Top Expert:
  • Tablets & eR... Master
  • 22,204 Answers
Check and test charger and or battery
Posted on Aug 02, 2019
    Top Expert:
  • 8,537 Answers
Hi Elizabeth.
Problems charging Android tablets usually stem from either the charger or the charging port itself. If you notice your tablet isn't charging, set it to Air plane Mode and reduce the brightness to extend the battery life while you work to solve the problem. Back up your files while you can, in case the problem can't be solved at home.
Sometimes the problem is with the charging port of the tablet itself. Examine it to see whether it's bent or misshapen. The connector on the charging cable needs to be able to fit well, so that all the pins on the charger are correctly attached to those on the port. If your port is damaged, it may need to be fixed or the entire unit may need to be replaced. You should also check the connector on the charging cable to make sure that port is correctly shaped and not damaged.
Sometimes using an incorrect power adaptor can prevent a tablet from charging. Look at both the base of the adaptor that plugs into an outlet and the cable itself. Very long extension micro USB cables, for example, charge more slowly than shorter OEM cables. Check the manual that came with your tablet to see what type of charger you need. If you're charging the tablet from a computer USB port, it may prevent the tablet from charging correctly. Use a wall adaptor and see if it fixes the problem.
or go to this link and read up some more on this matter.
https://www.google.com/search?q=tablet+will+not+charge&rlz=1C1AVFC_enGB797GB798&oq=tablet+will+not+charge&aqs=chrome..69i57j0l5.658j0j8&sourceid=chrome&ie=UTF-8
Posted on Aug 01, 2019
SOURCE:
Can I buy a power cord that charges while you are using the tablet?
all tablets can charge while you are using them, on rare occasion the battery will completely discharge and will need to be charged to the minimum before operating the tablet.
Feb 06, 2016 | Hipstreet Flare 2 9 inch Tablet with 8GB...
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
Digiland tablet won't charge. Is there a way to
Depends upon exactly what's happening.
  • When you plug in your charger, does it try to charge the Tablet? ie Does the Charging icon come on the screen briefly when the charger is plugged in with the Tablet turned off, or does the little charging 'lightning' symbol come onto the battery icon on the home screen when the Tablet is running?
  • I assume the battery has gone flat, but will the Tablet turn on when the charger is connected?
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
Dec 30, 2014 | Tablets & eReaders
It will not charge
Try to charge your tablet pc with your laptop or desktop pc.
if it will show the charging then your charger may be out of order.
if it will not charge with your laptop or desktop then your tablet's charging circuit not working.
Feb 15, 2014 | Ematic 7" Tablet Computer
Battery will not charge
it means that something is wrong with your battery or its charger
Feb 02, 2014 | Android Coby Kyros Mid7014-4g 7" Tablet
My tablet won't charge.why???please help!!
Is your battery removable? Try removing the battery and then plugging in the tablet. If the tablet runs on only the AC power, then your battery is shot.
Dec 29, 2013 | Dell Latitude XT2 Tablet PC
ASUS Tablet TF101 Wont Charge
batteries do not last forever get it replaced by a computer shop
Jan 05, 2018 | ASUS Eee Pad Transformer TF101A1 Tablet...
Tablets & eReaders Logo
75 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
