Make sure both inside and outside fans run and circulate air freely.
Outside fan can clog the condenser radiator coil with lint and dirt. Inside fan evaporator radiator coil can freeze up to solid block of ice having no free air flow.
Maintenance includes inspecting those things, free air flow thru coils.
SOURCE: GE side by side fridge not cooling enough Freezer side was still
check see if you have frost build up in the freezer back wall you may have defrost problem
SOURCE: my frig is running but not cooling - frig is 50
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Testimonial: "Thanks for the quick help - yes frost on back wall. Once I unload and defrost should I then take out defrost thermostat? "
SOURCE: GE Monogram refrigerator does not cool.
I need you to pull away from wall and remove cover over compressor and feel compressor for heat. If too hot to hold hand there or if warm or just cool. Tell me what you find. I would like to help you solve this if you like. Sea Breeze
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
