First of all use the larger output amp to power the sub. You can tell if its free-to-air if in the middle of the magnet there is a hole for "air" to flow freely. The advantage of free to air is they dont require much of an enclosure or next to none so you can mount it on a single piece of mdf wood and use the cab in the truck as an enclouse itself. I would bridge the amp for the sub to mono but be careful to tune so you dont "distort". Secondly the amp for the mid's shouldn't be bridged any maybe you could run the front and rear speakers off the same amp.. I would get an amp for rear and front speakers each and one for the sub. Your ouput rca's should goto the cross-over first then to the amp (sub) - then wired to your sub (mono) which is bridged. Ensure to tune your cross-over to lowest frequency for sub. Its easy to bridge an amp if its 4 channel.. looking at the speaker terminals it will look like ( + - + -) use the two outer most terminals to bridge to mono.
