Epiphone Les Paul Studio Electric Guitar Logo
Posted on Sep 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I tripped over my amp chord while it was in, and now my amp wont make any sound at all. any suggestions?
Jerry
Level 2:
Scholar:
  • Expert 35 Answers
  • Posted on Sep 13, 2009
 Jerry
Expert
Level 2:
Scholar:
Answers
35
Questions
0
Helped
16519
Points
114
First, try a different cable. Often in this kind of accident, the connection is broken between the wires in the cable and the plug on the end of the cable. (The cable can often be repaired by soldering the wires back onto the plug.)
If that doesn't help, it's possible the input jack on your amp was damaged. It is a relatively simple job for an amp technician to repair or replace an input jack if this is the problem. Expect about 1 hour of labor and about $10 in parts.
Casio LK-100 keyboard is turning off often when chords are played, esp in lower octaves - seems like a short. Where might the short be - way to fix without taking the whole keyboard apart?
Sounds like a lack of power from the external "wall wart" power supply. Is it the correct one that can supply enough current for a chord to be played? (a chord will play more notes at the same time & pull more power from the supply in order to make the sound(s)) If it's the correct power supply or one of the correct current rating check the cable & the connector both at the end of the cable & where it plugs into the keyboard. Perhaps the lead has been tugged accidentally? / Damaged in some way? Turn the volume down a little & see if that helps - that will confirm the power theory :-) Good Luck!
Jan 17, 2017 • Casio Music
What are all the left side controls on an Elegance JC-618 electronic keyboard
Single and Finger,is chords mode.
In Single,by press one key (eg:A) then chords A is heard,and so on.
In Finger,you must press 3 keys.Example: G-B-D,then you heard G chord. D-F#-A is D chord.
In Finger,lets say you press A chord and want to change to C chord by press one key C only,there's nothing change untill you press C-E-G.
Low, is for chords octave low.
Chords Off,no chords can be play,it mean overall full piano mode..
Single,Finger,Low, can be activate with Sync Start button.
Aug 17, 2015 • Music
2answers
Hi, when I play a chord on my Casio-656 keyboard it sometimes sounds out of tune - if you hit the chord again it plays correctly. Is this a fault or a setting? It seems to be intermittent so that would...
I would check your fingering... You MAY be late in hitting a particular note and the using auto chord... this can cause the problem. Another thing is if notes are hit with different velocity that can affect the sound. Sometimes certain voices have VELOCITY switching which actually changes the voice depending on the velocity you hit a note.
May 19, 2011 • Casio Music
Fuse blew out on my american audio after my girlfriend tripped on the chords, how do i repair it . is there a fuse or a reset button thank you
You are saying the fuse blew out and then asking if there is a fuse??? That makes no sense...
Tripping on cords could do certain things but NOT likely to blow a fuse.
Tripping on cords OFTEN breaks the plugs on the cords or the jacks in the equipment. The power input jacks from those wall transformer power supplies seem to be very vulnerable to this. They often disintegrate OR break loose from the solder on the circuit boards rendering the unit inoperable.
In future, loop the cords through handles so they don't yank the jacks if somebody yanks the cord.
Hi my Marshal G15 is making an echoy twang when played loud (& open E chords). does this mean the reverb is broken?
I suspect the vibration when it is loud is vibrating a reverb tank within the unit.
Test this bylistening with headphones and see if you get same sound.
It may be the reverb has a resonance or the cabinet does that is sensitive to your E chords.
The shock mounting of the reverb may have failed to isolate the reverb tank from speaker vibrations... hence the headphone test.
2answers
My electric guitar wont play with my amp
Yes its probably the wirring but if u look at it
it kinda crazy, so you wont be able to do it on ur own unkess ur a guitar tech so just go to a shop and they will fix it for u, problem is that if it is the wirring it willl have problems, so u might want to replace the WHOLE wirring system... Depending on the guitar u have, FENDER< GIBSON<IBANEZ, CORT, the wiring colors will be different
DONT TRY TO FIX IT URSLEF
1helpful
Casio tonebank ct700 no sound from chords only whilest on fingered chord please advise
More info. If you are chording on the left half of the keyboard, SOMETIMES they allocate or have the option to select a different voice for the part where chords are played. For these, you have to ALSO select a voice for that half of the keyboard. If you don't select a voice, then you would not have anything sounding.
Sep 27, 2009 • Casio Music
Top Epiphone Music Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
tednugentlives
tednugentlives
Level 1 Expert
Are you an Epiphone Music Expert? Answer questions, earn points and help others
