Evenflo ExerSaucer SmartSteps ABC Stroller Logo
Posted on Sep 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I lost the instructions to our evenflo exersaucer 3-1
We lost the instuctions to the exersaucer and it isn't ours...is there a website or a place where i can get a new copy of the instructions??? PLEASE HELP
Anonymous
Level 2:
  • Expert 74 Answers
  • Posted on Sep 13, 2009
Anonymous
Expert
Level 2:
Answers
74
Questions
0
Helped
36859
Points
151
If you go on the evenflo wesite. you should be able to type in the product you purchased,then a list of options should come up one being the instruction manual which is downloadable or read from screen.
How to convert evenflo exersaucer
Here's a step-by-step article for converting the Evenflo Exersaucer. It has photos and videos. How to Convert the Evenflo Exersaucer into Stage 3
I need to fold the evenflo exersaucer to store it
Unfortunately, folding it to store is not a simple task. You'll have to remove the base which will allow you to fold the legs. Although the article I'm referring you to is for converting the exersaucer into a stage 3 activity table, it does give instructions on how to remove the base which will allow the legs to fold. How to Convert the Evenflo Exersaucer into Stage 3
11helpful
2answers
How do i convert it into the s shape activity center
hi here are the instructions
https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=6231883&txSearchDOM=1/1/2010
11helpful
2answers
I am needing an instruction manual for an Evenflo Exersaucer Triple Fun 25800496 08/06
hi
here is a page link to instruction download
near to bottom of the page
2helpful
How to put the cloth seat back on
http://www.evenflo.com/resource.aspx?id=467&rcid=19
This may not be the one you have but this site will advise you how to get model and manufacture date so that you can get exact instuctions.
13helpful
2answers
I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Lost instructions to the evenflo triple fun excersaucer
put the bottom and top togather where the 3 holes are on top put the springs put the caps on and turn them. You will have to use a little pressure but they will turn
Lost instructions
please call a ParentLink Representative at 1-800-233-5921, Monday - Friday from 8 am to 5 pm.
https://plweb.evenflo.com/replacement_parts.aspx
This is the link to the evenflo toy site, it gives the instructions to call and talk to an agent. Hope this solves your issue. I don't have the toy.
9helpful
Evenflo 3 in 1 Exersaucer Triple Fun
https://plweb.evenflo.com/product_search.aspx?txSearchModelNo=6231711&txSearchDOM=1/1/2008
Look here it has the instructions.
Top Evenflo Baby Gear Experts
ZJ Limited
ZJ Limited
Jennifer Rock
Jennifer Rock
john h
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
