Televison & Video Logo
Posted on Dec 11, 2007
Code for Verizon FIOS remote Control
None of the codes listed in the Verizon FIOS remote Control work for turning the TX-SR605 on.  Two codes work for turning it off but will not work for turning it on.  The Verizon remopte is a Motorola DRC800
None of the codes listed in the Verizon FIOS remote Control work for the ölevia 542i LCD TV. The Verizon remopte is a Philips RC144.
  • smb260 May 07, 2008
    I have a 32in Vizio HDTV and none of the codes listed work for me to use the verizon remote control. Anyone know any new codes that will help me out?
  • xbucknutx Feb 22, 2009
    I have a 37" Vizio TV and I am envoutnering similar issues. The provided codes do not work at all and when I do a code search (pressing the FF button a million times) I can find a couple codes that will work for powering the unit on and off, but none that allow the remote to contol all the functions it should like input selction, PIP, etc.
    Any ideas on where I can find more codes or what brand's codes will work?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 06, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2173
Points
Code 1292 worked like a charm for me!
Vizio SV421XVT
A
Anonymous
I have a sylvania???? i think thats what its called and none of the codes work for me and i have an oritron dvd and the code doesnt work either
I want to control my Sony Bravia KDL-46VE5 TV with my Onkyo TX-SR605 remote controller. I cannot find the Bravia remote control code.
Sony TV codes for the Onkyo TX-SR605 are : 0000, 0650, 1100, 1167, 1300, 1505, & 1651.
Instructions for the Onkyo RC682M and more remote codes are available here. The Onkyo TX-SR605 manual is available here.
I hope that helps.
3answers
1988 KAWASHO TV: Need remote control codes for VERIZON FIOS Remote Control
You may want to try a different universal remote, like the Logitech Harmony.
tip
Onkyo TX-SR605 Remote Codes
Download Onkyo TX-SR605 Remote Codes
4 Digit Onkyo Remote Codes
Models: RC-682M / TX-SR605 / TX-SA605 / TX-SA8560
Have you misplaced your Onkyo TX-SR605 Remote code list / Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Universal Remote Code List Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
_________________________________________
Download Onkyo TX-SR605 Users Manual Here.
tip
I hope that helps.
1helpful
No codes for remote verizon fios control of tv came with tv or are listed for RC1445 302/oob manual
for my tru-tech i used the auto code finder on the Fios remote instructions it didn t take very long, I can t say the same for my memorex tv though.
Need to program fios remote for Dynex 26 lcd
i looked on verizon for you try the dynex website
1helpful
2answers
Code
Hi
I have a Panasonic viera TX-32LMD70 TV and a Panasonic
remote control. I also have sky and I cant use the sky remote
control for the sound when I try to change it asking for the code
and I do not have any for the panasonic remote how came with the TV when I bouth it. Can you help me.
Thank you
Gill Plimmer
1helpful
FiOS TV remote control
bought an new one for $5.
17helpful
10answers
I have a solution which has worked well for me. It uses the DVD button at the top of the remote. It was a trade-off as none of the codes in the RC144 Philips remote will work any Blu-ray players, so the DVD button was unassigned. The 922, 955 and 977 codes are explained in the directions for the FIOS remote. http://onlinehelp.verizon.net/consumer/bin/pdf/philips%20rc1445302%20user%20guide.pdf
1. Set up your TV button to work your TV.
2. Set up your Onkyo code, pick one to turn on the receiver. I used 3719
3. Use the 9-2-2 code to cycle through all available codes. At about a count of 300 I found one which will turn the Onkyo receiver off. Make sure you start this process with the ONKYO receiver already on. Once you find it press the OK button.
4. Use the 9-7-7 code to power all devices TV, AUX and DVD from the power button.
In this way, each time the power button is pressed it will send both the power on and power off signal to the ONKYO receiver.
This technique works well when you point the remote at the ONKYO receiver and press power button. Apparently the TV has better reception for the signal then the ONKYO does.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
