You need to do what is called a hard reboot on your phone. if you call customer service they can walk you through it. this will reset the phone to original settings.
Well,
Connect it to your PC then use the arrow keys of the mobile to change the transfer mode to PC SUIT
mode.
The PC SUIT selection might be up or it might be down,so try both,first try up then press the ok button
of the mobile,if it doesnt show the PC SUIT mode on your PC,disconnect the mobile and re connect it
again then try the down key and press the ok button of your mobile.
This will work 100%
Open your usb cable with a sharp knife; you'll find four different coloured cables inside: leave the red and black cable intact; cut the other two. Close your cable with some tape.
Your navman won't go into usb mode again, but it will charge your device
from the userguide I found that you::
1. Press MENU, 9, 7
2. Use the navigation button to select a setting,
then press .ok
USB Modem/ USB Mass
Strorage/ Bluetooth/
Setting Reminder
Here's a work around. 1) Plug the USB cable in and let enter Sync Mode as usual. 2) When the Garmin unit is in Sync mode, unplug the USB cable. 3) The Garmin unit will start to exit Sync mode, at which time, IMMEDIATELY plug the USB cable in again. 4) If you plugged in the USB cable in time, notice the Garmin unit will remain out of the sync mode.
Click on this link and navigate to page 61 (USB Mode) to learn how to transfer pictures.
You will have a USB cable provided with the cell phone. Connect the USB cable to the phone on one end and the computer on the other end. The phone will be detected automatically. You can then go to My Computer (Win XP) / Computer (Vista) to check for the device. Double click the new device attached and open the files similar to opening any other document in the computers.
>> To transfer files using PC Studio, from a PC to the handset, follow the steps below:
These instructions assume you currently have PC Studio. If you do not, please check the Samsung Accessories site to purchase the software.
If the application is not yet installed, insert the CD into the drive on your PC and follow the on screen instructions to install PC Studio 3.0 (version 3.0.1) NOTE: DO NOT CONNECT USB CABLE DURING PC STUDIO INSTALLATION
Confirm the handset's USB mode is set to PC Studio by following the steps below:
While in standby mode, press the left soft key for Menu
Select Settings (9)
Select Connectivity (6)
Choose Select USB Mode (4)
Highlight PC Studio, using the navigation keys
Press the left soft key to Save the USB Mode settings
Launch PC Studio 3.0 (version 3.0.1), you will see "Not Connected" in the bottom right corner
Plug the USB cable into both the handset & the PC, you will now see "SGH-a727 Connected" in the bottom right corner (See example below)
Click on Transfer Files, you will now see the PC Studio Phone Explorer appear
Navigate to the location of the file(s) to transfer then highlight the desired file(s)
Click on To Phone, on the Phone Explorer menu bar (See example above) to copy to the handset
From the Search Folder screen, Navigate to the desired destination on the handset
Click OK to copy the selected file to the handset's memory
PC Studio Checklist:
Make sure your USB or Serial cable is compatible with your phone model. You can always check for the correct data cable by looking at the model number on samsungmobile.com in your phone's accessories section.
If you are using a Bluetooth dongle or IrDA port as your connection, the necessary driver(s) should be provided with their data kit and should be correctly installed and set up prior to the installation of PC Studio.
Hints & Tips:
Remember to select file formats and file sizes supported by the phone when uploading files to the phone from the PC.
Remember to select the correct destination folder in the phone when uploading files to the phone from the PC (e.g. mp3/aac files-> music folder, jpeg/gif files-> downloaded images folder, 3gp/mpeg4 files-> downloaded videos folder...)
Have you tried a Master Re-set when the phone is off? Hold the center key and the power button for at least a FULL minute to a minute and a half. You will see the provider's splash screen, but hang tough.
This works best with the device on a flat surface rather than holding it.
