Televison & Video Logo
Akinbi Oluwadamilare Posted on Jul 29, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My JVC 32 smart TV is having lines horizontally across the screen and image turned upside down
Larry
Level 3:
  • JVC Master 5,042 Answers
  • Posted on Jan 12, 2022
Larry
JVC Master
Level 3:
Answers
5042
Questions
Helped
1239569
Points
18413
See if your set has a mirror setting...if it does turn it off or on
5 Related Answers
pishta68
Steven Wander
  • 599 Answers
  • Posted on Feb 17, 2008
SOURCE: Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Anonymous
  • 446 Answers
  • Posted on Aug 28, 2008
SOURCE: Horizontal lines appear across the image
replace the ink cartridge
Anonymous
  • Posted on Feb 05, 2009
SOURCE: Panasonic 32 inch TV has horizontal lines across screen
REPLACE VERICAL OUTPUT IC ' LA7838
vic richards
  • 75 Answers
  • Posted on Mar 09, 2009
SOURCE: TV: bright line across black screen for several hours.
vertical problem need to check for bad solder joints on vertical ic would be helpfull if we had the model number o f yur set. also could be bad capasistors in vertical section.
Anonymous
  • Posted on Oct 18, 2010
SOURCE: have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
4helpful
White lines across the top of the screen
It sounds as though you can see Transmission lines which are sent out with any broadcast at the top of an image, The TV should normally blank these out, i suggest checking your horizontal and vertical settings
Video just reduced to a tiny horizontal line across the screen. sound is fine, what could be the problem? jvc tv model av-32720
You have a bad vertical IC at its worse or one that may need resoldered. Be sure to check the grounds on this IC and check for rings around the pins. And you can bet in the immediate area you have bad capacitors that created a hot vertical IC. This will cause the Vertical IC to break down!
2helpful
32 ''Sanyo DP32648 TV has horizontal line running across screen
If you do not have any bad capacitors Problem will be the Display Panel
Call Encompass Parts Distribution or visit their website and type in your Model number 1-800-638-3328
5helpful
3answers
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Horizontal lines across the top of the screen
Hi and welcome to FixYa,
Your described problem is indicative of a failing or near end of life capacitor in the vertical section. The capacitor (often called pump capacitor) would be in the neighborhood of 100uF 35V and physically near the vertical IC. In some JVC models, the vertical IC would be an LA7838 or LA78041 usually a single inline package on a heat sink.
Cost wise, the capacitor is relatively cheap a dollar or less. What would be more challenging is getting access underneath the PCB to de-solder and solder in the replacement.
Pls post back result(s). Good luck and Thank you for using FixYa.
3answers
White horzontal lines on the top of screen
Typical symptom of a faulty screen voltage capacitor. You'd need a schematic to locate the cap and then change it out.
Geno
32 inch jvc av-32d302
Those are called retrace lines. The electron beam has to go back to the beginning of the screen as part of its raster scan. Normally it is turned down so that it can't be seen. There is a little adjustment knob on the high-voltage flyback transformer called "screen" that will hopefully adjust this for you. If that doesn't work it is an indication that the high voltage circuit is dying.
Hop Ya Fix It.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
